JFP in PA
  1. I try cleaning up the bleeder valve and putting on a new cap, if the crud returns, you can easily rebuilt the unit, or just replace it; one word of caution: Be careful with the screws on the bleeder, they snap off if you look at them the wrong way.........
  2. If you are refering the the small shaft under the bail moving up while the car is hot; yes, it is supposed to do that. More likely is that the cap is bad; what are the last two digits on your cap?
  3. We have a couple of the older cars running them, no problems to date.
  4. The unit with the external spring is the newer design that is supposed to keep the tensioner paddle from "flapping" until oil pressure has built up. They seem to work well.
  5. Take it to the dealer so the problem is at least on record. Ask them to check the cam deviation values at idle; if they are steady, you are in good shape; if they swing back and forth, you/they need to worry. Try running a heavier weight oil; I prefer 10W-40, many like 5W-40. Pull the oil filter and cut it open; if it is clean, you are in good shape; if it holds metal flakes, specs of flat black plastic, or granular metal the can be picked up by a magnet, you/they need to worry.
  6. Glad to hear you got it sorted.
  7. As the washer protects the alloy crank carrier from wear, I don't think ignoring it is a long term option..............
  8. It is a thrust washer, #24 in the diagram and it will require considerable disassembly to access:
  9. Not necessarily, but to know for sure, you must have the codes. Do you know anyone with a Durametric System? Otherwise you need someone with either a PSTII or PIWIS unit…………..
  10. What you are seeing it the cam's deviation from its ideal position (this is normal, caused by mechanical tolerances, slop in the chains, VarioCam, etc.). Usually at this point, the owner/operator instantly panics and starts call everyone because they think the values they see ( something like your -1 and -0.5 ) means their engine has jumped time, when it is completely normal deviation from ideal values. The cam movement with increasing and decreasing RPM is the action of the engine’s VarioCam, again completely normal. As long as the cam deviation values remain steady at an idle, everything is fine; if they start jumping back and forth, that is another issue entirely. There was a posting in the archives of a Porsche article that explains in detail both VarioCam and VarioCam Plus systems and how they work. Might make good introductory reading…………
  11. I could be wrong, but I think it is only in the "Pro" version. You also need to keep in mind that Durametric, unlike a lot of other systems, is a "work in progress", but does provide updates.
  12. +1 on Loren’s comment. Clearing a code, particularly an unknown code (not read) is asking for grief. Take 5 min., get it read, and you will know what is going on…….
  13. It was "obvious" to me because I was looking at their "Pro Line" system which bundles a lot but costs more as well; so yes, you can get it at the price you outlined. That said, the last time we evaluated the Pro Line for the shop, the Durametric Pro system still had several advantages as their system could not test activate several systems, including the VarioCam solenoids (a common test), the fuel pumps, the ABS/PSM pump, plus several others. It also seemed to have difficulty with clearing some of Porsche's "restricted" code areas. I don't know if they ever corrected that, but the Durametric Pro system handles all of them, and regularly adds more. I know some find the Durametric confusing, but when you use it everyday, more and more becomes obvious. We would have added a PIWIS unit and gotten just about everything, but Porsche has priced that outside the realm of reality........
  14. The sensors and wiring are the easy bit, cars with the factory leveling system also can run diagnostics on the lights through the DME using PIWIS/PSTII, and there is at least one systems fault indicator (Code) for the leveling system alone, plus others for various functions’ in the lights; indicative of the system being routed and controlled through the car's computer system. How do you plan on making that connection and activating it?
  15. The auto leveling sensors attach to the front and rear suspension and require an entire wiring harness of their own. To my knowledge, retrofitting auto leveling is neither for the faint of heart or wallet, which is why no one attempts it………….
  16. There is a Schrader valve (look like a tire stem valve) on the fuel rail. You can jump the relay, or just turn the ignition switch on (does the same thing). If you have access to a PIWIS/PSTII/ Durametric system, all have the ability to cause the pump to run. I think the test is also covered in the Bentley manual. You will need to get a new cap and seal for the Schrader valve, they are not reusable, but only cost a few cents……….
  17. The fuel pump has two critical parameters: Fuel delivery volume (measured in mL/min.) and pressure. A pump can deliver considerable volume, but the injectors still will not operate correctly without the correct level of pressure. All M96/97 engines came equipped with a test port on the fuel system for testing both. If the pump cannot deliver the correct pressure range, the volume delivery becomes irrelevant..............
  18. Life would be a whole lot simpler if you connected a fuel pressure test gauge to the test port and checked for the correct pressure..................
  19. And have you checked the battery (e.g.: had it load tested)? Would not be the first brand new dud we have seen..... You could also be having parasitic current draw issues that are pulling the battery down; does the car have any aftermarket electrical/electronics in it?
  20. Let's see; $250 for the tool, then $1300 for the Porsche specific add on; vs. $287 for the Durametric "Enthusiast" or $735 for the "Pro" version. Kind of seems obvious.......
  21. dumb question here... what exactly is the rotating assembly... is that not on the flywheel... is it a separate component? as for the X51 baffled pan.. its does provide *some* benefit that's for sure... but I definitely agree that it is only the 1st (and IMO necessary step) in upgrading the oiling system... I'm curious if there are folks who have done both X51 AND deep sump pan (which holds about 1/2 quart extra only) that have seen more stable pressures in corners where oil pressure was previously unstable. I know of an outfitter here in Canada that makes a sump kit that holds a *complete quart* of oil with spacing hardware and that would certainly help to ward off starvation a bit better than just 1/2 a quart; if the oil your engine needs is suspended in one corner of the engine during a high g corner it will never make it back to the sump and hence never pumped to where it is needed... (this is where complete X51 oiling kit comes into play - pumping it back into sump) and the theory of having a full extra quart means that it was never pumped and is ready as "reserve"... many are doing this but I haven't heard any feedback that shows a change in oil pressure; I have an X51 pan only and *think* I see a SMALL difference but I will do more testing this summer that's for sure as I have made less than scientific observations. a lot of the oil trying to drain back into the sump gets "stuck" in the cylinder bank towards the outside of a given corner, and the oil in the sump stands up on the same wall of the sump. Not a good thing. yes but I thought with x51 with the walls built in *around* the tube it forces a much smaller perimeter and keeps the oil in place during high g cornering so the pick up tube has something to suck in... it also has the baffles that open and close to trap oil in that little box round the pickup tube... in a non-x51 pan I can see the oil being cornered on the far wall away from the pick up tube but I don't believe this is happening with x51 pan... unless of course that corner is so long and sweeping and you are generating serious g force for a long time so that it picks up all the oil the x51 pan has collected and now its stuck on top of one of the heads waiting for the g-forces to stop so it comes back down... <- that can definitely happen and from what I'm told will blow the motor; so the question is whether putting in an extra litre of oil with a deeper sump pan makes that condition less likely and I think it does.. btw ... I never knew the x51 pan with baffling allows an extra 1/2 litre of oil... interesting... All M96/97 motors, down to the lowly 2.5L have fully baffled sumps with trap doors to limit oil movement right from the factory. The X51 (first photo) is a bit deeper and more elaborate, but very similar to the base system as seen here (second photo):
  22. so unless you take apart your engine to balance all the above parts *with* the new LWFW your saying don't do it? I would not. But everyone must weigh the risks and make their own decision. ok... thx for clarifying... that's why lots of the engines that have this mod added eventually give out early.. but not all though... its a crapshoot +1 on Loren's comments. This is what was left of a factory X51 motor running a lightweight flywheel.............
  23. We have several customer's running the Accusump system, some which we installed. Is there something specific you want to know?
  24. dumb question here... what exactly is the rotating assembly... is that not on the flywheel... is it a separate component? as for the X51 baffled pan.. its does provide *some* benefit that's for sure... but I definitely agree that it is only the 1st (and IMO necessary step) in upgrading the oiling system... I'm curious if there are folks who have done both X51 AND deep sump pan (which holds about 1/2 quart extra only) that have seen more stable pressures in corners where oil pressure was previously unstable. I know of an outfitter here in Canada that makes a sump kit that holds a *complete quart* of oil with spacing hardware and that would certainly help to ward off starvation a bit better than just 1/2 a quart; if the oil your engine needs is suspended in one corner of the engine during a high g corner it will never make it back to the sump and hence never pumped to where it is needed... (this is where complete X51 oiling kit comes into play - pumping it back into sump) and the theory of having a full extra quart means that it was never pumped and is ready as "reserve"... many are doing this but I haven't heard any feedback that shows a change in oil pressure; I have an X51 pan only and *think* I see a SMALL difference but I will do more testing this summer that's for sure as I have made less than scientific observations. The “rotating assembly” is the pistons, rods, rings, bearings, wrist pins & associated hardware; plus the flywheel. The X51 sump cover and baffles assembly does add about ½ quart of capacity, or about 5% of the total. While the extra oil is a good thing, if you stop and think about the fact that it is such a small portion of the total available oil. A properly done competition oil system works with three factors: The quality of the oil (the rating or grade of it), the condition of the oil (its temperature, shear condition, viscosity), and the location of the oil (where it is inside the engine). Because these cars are capable of tremendous cornering forces, if the oil is hot, thin, and most of it is trapped up in the engine assembly; what is left can easily get stood up (literally) on the sidewall of the engine cases, and your pump momentarily runs dry. Not a good thing. Because of the “boxer” design of the engine (flat opposed six), a lot of the oil trying to drain back into the sump gets “stuck” in the cylinder bank towards the outside of a given corner, and the oil in the sump stands up on the same wall of the sump. Not a good thing. The full X51 system helps collect that oil and get it back into the sump, lessening the change of the pickup becoming uncovered, and bearings being without oil; which is obviously a very good thing.
  25. I have, and I would definitely recommend against using a light weight single mass flywheel unless the rotating assembly, and the flywheel, are fully balanced as a unit before the engine is assembled. A lot of people seem to think that they can simply slap on an X51 sump cover and all is well, when the reality is that the sump cover is probably the least important component in the upgrade.
