juniinc
Everything posted by juniinc
  1. looks like a hands free mic.
  2. :clapping: :clapping: :clapping:
  3. http://www.renntech.org/forums/index.php?s...c=17259&hl=
  4. washer fluid,,, try to see what's in the reservoir.
  5. yes, I changed the oil on my MB S500 with a siphon pump.
  6. looking good! Turismo,,,gorgeous wheels. Any reason U didn't go with black finished Florio? just my opinion Phillip ;) .
  7. H&R of course. Yup, longer lug bolts are needed. Let me know If U need some.
  8. My dealer will do it for $350 in about 1.5 HR.
  9. Nope, the micro sw will not lock the motor in a single way. There are 2 white switched wires that runs to the motor(12V+up & 12V+down). Check those 2 wires from your driver's side switch. Then Check/meter both up+down+ hot wires at the motor. This old thread might be able to shed some light,,, http://www.renntech.org/forums/index.php?s...indow&st=40 Thanks for the info. if the door microswitch is faulty would it lock the motor in a single one way postion when the motor is out of the regulator, I am suspecting a microswitch problem, but why won't the windows switch work either, I'm going to see if if is possible to turn the regulator manually, to drop the window a bit and reattached the motor and see what happens. Is there a way to reverse the direction of the motor?
  10. It is an offset problem. Im running a set of 18x11 on the rear,,, wasn't rubbing while she is parked, but rubs with more weight in the car + hard cornering. Ended up installing s set of H&R 7mm spacers.
  11. by using a volt meter or tester, best to check the constant 12V hot + switched 12v while turning the ignition. Hmmm, if it is the ignition switch it would be a hell'ova coincidence. Everything worked perfectly before I put the car in stands. I think im gonna try and re-charge the battery and see what happens...
  12. I still got some OEM/after market lug bolts.
  13. :clapping: :clapping: :clapping: What if they were white,,,,
  14. Nope, I don't think so.
  15. H&R makes em all the way up to 65mm. Would 23mm do? http://www.automotion.com/product.asp?pf%5...;dept%5Fid=5128
  16. exit the vehichle, close the door, arm it, wait a few seconds, then stick your hand in there see what happens.
  17. If U can hear the motor turing , at least your relay+motor is OK. The sunroof motor drives two cables that move the roof forwards and backwards in a track. Most likely its the broken cable or the gear drive teeth wearing out. Check for a broken cable. Sunroof panel can be removed, slide it backwords first. Yes U can move it manually in emergency mode. Each part can be ordered, even a gear drive. Good luck.
  18. I would check the clutch sensor again,,,, Here is how it goes. BATTERY (RE)---> CURRENT DISTRIBUTOR F4 80AMP(RE/WT)---> *CHECK THE IGNITION LOCK F4 80AMP FUSE IGNITION LOCK(YE)---> START LOCK RELAY(YE)---> *CHECK THE START LOCK RELAY SUPPORT REAR STARTER I hope this helps.
  19. STP is just fine,,,, I've used several of them already on my 986S
  20. Yup that is how tolum fixed his,,, http://www.renntech.org/forums/index.php?s...c=22084&hl= http://www.renntech.org/forums/index.php?s...c=22690&hl=
