bigbuzuki
Everything posted by bigbuzuki
  1. There is an updated nav cd available which was dated 2008. Part number is 99664203602. Cost is about $1000 in Oz. You can get it for $466 USD from www.porscheoemparts.com Could be worthwhile in purchasing a Tom Tom nav unit instead.
  2. I researched this a little while back. The info I received stated that the pump in the tank which had low fuel would be shutoff to prevent such cavitation. It was unclear if this was a function of the fuel level sensor noting the applicable half of the saddle tank being low or in combination with a sensor monitoring the attitude of the vehicle if it was banked to the left or right whilst offroading over a hill etc.
  3. Porsche Technical Service Bulletin 3965 lists all the approved oils and quantities for changing the final drive differentials and transfer case oils. You can download it from this site if your a contributing member.
  4. Try depowering the rear control unit by pulling the applicable fuse for a few minutes and see if that resets the system.
  5. Natty, those prices are too high. Plug your part numbers into www.porscheoemparts.com and save approx 50%. Also the retaining frame is probably not required.
  6. Looks like the "closing aid" circuit is not working. Fuses to check are in the dash right hand side fuse panel. Fuse #30 is 20 amps and supplies power to the "closing aid motor". Fuse #31 is 15 amps and supplies power to the "rear comfort sysytems control unit" which controls the motor. Good luck.
  7. There are position potentiometers on the servo loop for the mirrors. With time they wear and may not be reliable when it comes to transmitting feedback position information to the control units. In short the motor assemblies which contain the feedback pots will need replacing.
  8. Could be wise to change the transmission mount as well.
  9. IIRC to remove the gauge needles from their shafts was a matter of pushing and turning the needle anti clockwise about 1/8" from it's natural stop and then pulling it off it's spline. Same pushing, anti clockwise procedure and pushing them on for reinstalling.
  10. http://www.porscheoemparts.com has them for US $208.00
  11. Just a caution regarding the use of non approved fluids for automatic transmission changes. The OEM fluid used in the Aisin transmission is mineral based and approved by Porsche, it will not void your transmission warranty. Using an alternate synthetic fluid is unapproved, and will void the transmission warranty as stated by Porsche.
  12. My Cayenne doesn't do this. Neither does mine with 155,000 km.
  13. You should be able to hear the compressor running under the front right door sill area. You can test by plugging in your tyre filling hose at the seat adapter and switching ignition on. There is a 40 amp fuse under the front left seat fuse block that blows if your compressor motor has failed.
  14. If your compressor isn't running the repair kit you ordered will be useless.
  15. Can you hear the compressor running when selecting a different height setting?
  16. The Aisin transmission factory spec is a mineral oil. Dealer did a transmission oil change recently after changing my trans valve block under warranty. I was advised against using synthetics as they are "not approved", voiding my warranty. I wasn't going to argue.
  17. Mobil 1 has given you 200,000 turbo kilometers in what sounds like extreme climatic conditions. Stick to the proven product.
  18. Is the vacuum pot for the waste gate a replaceable part ?
  19. Put an exhaust on yours to make it sound wicked.
  20. Some of the 06 Turbo S differences over a 04 Turbo which would impact on handling would include the following: Reinforced spring struts, larger brake discs and brake calipers, reinforced tie rods as well as improved improved rubber mounting on the control arms, new level control unit.
  21. The doors do sag with time. I had an issue with my drivers door and had the hinges realigned at the dealer.
  22. I find it hard to believe that there were no fault codes generated and stored with a red suspension warning. I would be looking for another workshop to get the fault codes read.
  23. The V8s had an issue with the fuel tank vent valve being faulty. This caused the engine to have a starting problem, especially after refueling without the CEL illuminating. Faulty fuel caps caused these type of issues as well. Does the V6 also have some type of fuel tank vent valve or fuel cap issue causing a similar issue?
  24. Durametric indeed does allow you to talk to the seat control unit.
