I did a search for TPMS and from all the results, nome came from the 996 section. Has anybody successfully installed an after market TMPS on an 996? Mine is a 99 and I am thinking about doing it. I have found several units online but can't decide on what direction to go.
  • 2 years later...
IMHO, TPMS were mandated by Big Brother because the average driver hardly ever checks his tire pressures thus leading to all sorts of negative handling.
I had them in my 335 E90 and hated them as the warning lights with message would come on either with a 1 psi drop in one tire or a slight mismatch in all 4. I had to stop the car and re-initialize the TPMS as the lights and warning were annoying.
If you are a car guy, and I believe you must be as you drive a P-car, I'm sure you check your tire pressures every 2 weeks as a matter of course.
In addition, the cost of these gadgets is over the top and I believe that not all wheels will accept them.
For a car guy they are a total waste unless they come pre-installed as of model year 2007.
I fitted the Orange TPMS to mine. It works very well, and wasn't expensive - I bought direct from Orange Electronics - around $120 IIRC. On the turbo I had to modify the metal valve stems in order to fit the sensors, but that wouldn't be required if you have rubber valves,
It is useful as a safety aid, and for setting the pressures accurately. If you do track days (DE days?) it would be invaluable, as you can monitor temperatures and adjust pressures accordingly.
Richard:
Which specific unit from Orange Electronics did you use?
Regards, Maurice.
I got the P409S kit. I just looked up the invoice, and it was $120, plus some extra stem spacers and hollow screws for the metal valves on my hollow spoke Turbo 2s. I posted a picture of the modification on a thread on the 996T forum around January/February time. Again, not required for conventional valves.
Edited by 1schoir
Richard:
Regards, Maurice.
