Ran out of gas, car is barely running now!
Cel on, scanned, P1502,,,so I tried to perform the throttle adaption.
No luck, just getting frustrated. I must have tried more than 20 times, ,,,still won't rev no more than 2000rpm.
I disconnected the battery then hooked it back up,cel gone, turn the key on for 1minute,turn it off for 10sec, pull the key out,,, I know the trick is wait til U Hear the TB motor engaging then leave it for a minute. Seems like no matter how many cycles I try my TB motor is not engaging at all.
Maybe it will take 30 key cycles LOL I'll open up the engine bay, dig it a little further tomorrow.
2000 986 S.
Thanks for bringing that up, I think it is the throttle unit for my car.
Fuel pump shouldn't turn on at all with a bad relay, should it?
I heard sometimes it takes more than 10~20 key cycles to get this adaption programmed. Maybe my DME needs to be re-flashed who knows!
Edited by juniinc
Hey what's that in your profile then, it says 2001? ;)
Same DME as 2001, same code.
To reset adaption, key on engine off 1 min. Key off 10 sec. key on again, Check and erase faults with code reader (i.e. durametric).
No the fuel pump would not activate if it doesn't have power.
2000 986 S.
Relays sometimes fail by going intermittant (sometimes work, sometimes do not). When this happens, the fuel pressure starts jumping all over the place.
Edited by JFP in PA
Relay fails as soon as I run out of gas, very rare coincidence don't u think?
unless it has something to do with low or no fuel pressure.
When I was cycling the key, as soon as I turn the key on I can hear the fuel pump come on but, doesn't CUT OFF at all?
I'm also wondering the cel code p1502 has to be cleared in order to reset this throttle adaption,,,I don't have a durametric at this point .
When u disconnect battery, I wonder if that clears fault code?
Relays fail under these conditions due to the excessive load on them when the pump starts to go in and out of cavitations as the fuel runs out; so no, it is not a coincidence.
Pulling the battery cable will clear the P1502 code, as will any scanner.
The relay is in the panel above the fuses in the left footwell, upper row, second from the left. You can pull the relay and jumper terminals 3 and 5 in the relay panel to simulate an operating relay (pump will be on all the time). The relay itself is a $10-12 item at retail, so I wouldn't put too much time into it.............
Problem solved for a few minutes this morning,,, started her up rpm won't go no more than 1500 then, I turned it off, back on for 1 minute, off for 10 sec, pulled it out then she started fine everything back to normal. Took her around the block, running like a champ. Back to the garage shut her off then started ,,,problem came back & still continues.
Weird
Edited by juniinc
Did you find the cure?
I did everything you did, and more. Luckily, or unluckily our winters are long, so I messed around with it all winter. Checking all the wiring, controls, etc.. Finally sent the DME unit to be checked. Will know the results in a few days.
I was just wondering what the fix is. No one I have seen on the inet has ever posted a resolution. I doubt there are thousands of these cars in garages not running. I do not have the luxury of being near a dealer or a qualified tech. Been working on my own pcars for over 12 years, but this one has me stumped.
No cure yet,,, haven't check the fuel pump yet.
It does feel a lot like a clogged filter or perhaps my pump is toasted as mikefocke mentioned. I believe these 2000 internal fuel pumps has a sock(mesh) filter,,,hard to clog that I'm thinking.
I will check the fuel pressure asap, is there any DIY For doing this?
Also waiting to hear Necad's result, I really think this really has something to do with throttle adaption communicating DME.
Edited by juniinc
You can start with post #19 here: http://www.renntech.org/forums/topic/32106-code-p1124-p1126-p0446/
I followed those links Logray posted, bought the right equipment, and tested my fuel pressure pretty easily. Somewhere further down those posts, I even put up links for where I bought my fuel tester (and adapter) from. Also, I believe the second link Logray posted in #19 says you can pick up an A/C tester that'll have the correct adapter for the fuel pressure tester port.
