Where is 997.618.516.01 located? Durametric calls it the Communication
Where is 997.618.516.01 located? Durametric calls it the Communications Front Control Unit (Comfort)
Battery died and after I did the emergency procedure to open the boot lid I got a C127 error, it goes away and then comes back intermittently.
TIA
CAM
:welcome:
You will find the front end control unit in the front trunk - right side - near the back of the right front headlight.
If the issue does not go away after replacing your battery - then you will likely have to have that control unit re-programmed by a dealer/OPC.
Sorry, that happens sometimes.
Why can't these cars be easier than that, I hate having to go to the Stealership.
I want to be able to diagnose my own problems, that why I bought the Durametric, and repair them myself.
Thanks for your info!
Edited by cam2008
  • 10 months later...
Did this change from year to year?  On my 2008 Carrera S, I found part number 997.610.105.11 in that location, not 997.618.516.01.
997.610.105.11 - Headlight Control Unit?
997.618.516.01 - Vehicle Electrical System Control Unit?
