Click here to Donate
102 outside and my turbo gets mad
Hi Community
Its unusual hot in germany. 102 outside.
After driving a lot today the car starting to make trouble . Looks like some kind of missfire when i am going downhill. Coming to Stops the car died several times. Its was starting again but very hard. Must be something with fuel?!
I noticed today that i isnt making "wooooosh" when i am opening the gas cap.
Could it be related?
Didnt have the Chance to check the Codes until now.
P0011 Adjustment of Inlet Camshaft in relation to Crankshaft, Bank 1 – Signal Implausible
P0139 Oxygen Sensor Aging After TWC, Bank 1 - Above Limit
P0159 Oxygen Sensor Aging After TWC, Bank 2 - Above Limit
P0234 Boost Pressure Control Limit Exceeded - Above Limit
P0441 Fuel tank ventilation system above limit value/below limit value
P2243 Oxygen Sensor Ahead of Catalytic Converter, Bank 1 – Nernst Voltage Line – Open Circuit
P2247 Oxygen Sensor Ahead of Catalytic Converter, Bank 2 – Nernst Voltage Line – Open Circuit
I would clear all of these - re-start the car, drive a few blocks -- then re-read any fault codes.
Sometimes codes are symptoms or a problem, and sometimes codes are the problem.  If you get a misfire, that's a symptom of something not being right.  Could be bad coils, plugs, an injector, etc.  If you have an open/short to ground code on a camshaft, that's saying the camshaft sensor is bad.
Sounds like the camshaft sensor is bad, and you have sometime of evap leak in the fuel system.  My guess is the camshaft is what's causing the engine problems.  I'd focus on that first.
Mine drives fine tested at 115 degrees in Tucson, AZ.  My pig had similar issues recently and it was just the fuel pump.  I had all kinds of codes from the car idling so erratically.  Nearly all the codes you had and then some.  Pull fuel pump fuse no.14 and see if she runs better at low RPM's on the secondary pump only.  That's an easy test.  Good Luck.
