Ignition Coil Packs
Has anyone used the coil packs on the link? They look to be good quality but anything could look good on the net. Has anyone used these before? If so how was the quality???
NEW 6 IGNITION COIL PACKS PORSCHE 1998-2003 911 3.4L 2.7L 2.5L 97-02 986 BOXSTER
In stock
$229.00
Set of (6) SIX high performance Porsche ignition coils (fits many models) check chart below
Direct replacement OEM fitment
- Improved Combustion
- Increased Ignition Performance
- Increased BHP and economy
- Improved throttle response and smoothness
- Smoother idle
- Eliminate engine misfires and hesitation
- No spark blowout at higher boost
- Direct Bolt in part / No modifications required
- Solid construction
- 2 Year Warranty
- MEETS OR EXCEED OEM PERFORMANCE
Brand New Coil / Coils in box.
http://napolperformance.com/porsche/new-6-ignition-coil-packs-porsche-1998-2003-911-3-4l-2-7l-2-5l-97-02-986-boxster.html
It's not an easy job putting coil packs in and it's not a job you need to do that often.  You may as well buy OEM parts, like Beru.  They are a bit more expensive, but they will go the distance.  The coil packs in these engines get very hot due to the closeness of the exhaust manifold.
I replaced mine and the plugs when the exhausts were off. It's much easier and it's not the difficult to remove the exhausts.  I found a "wobble" bar was useful on the ratchet wrench as it's difficult to get a straight line.
Edited by Hilux2400
extra line needed
