996 New driver part identification
Just picked up an 01 996 Carrara and PO had installed a battery tender on the passenger side beside the battery tray but it was no longer functional, so I removed it.  In the same area to the passenger side of the battery compartment there is a flexible clear tube unattached at its distal end originating close to the fuel filler neck.
Any idea what the tube is and is it correct for it to be disconnected
Depends on  the battery type.  The old lead/acid batteries needed to be vented.  Thus the clear plastic hose.  The newer AGM type batteries do not have a vent.  My current Duralast AGM battery does not have a vent.
