Just picked up an 01 996 Carrara and PO had installed a battery tender on the passenger side beside the battery tray but it was no longer functional, so I removed it.  In the same area to the passenger side of the battery compartment there is a flexible clear tube unattached at its distal end originating close to the fuel filler neck.
Any idea what the tube is and is it correct for it to be disconnected
6 minutes ago, Paul Forster said:
Sounds like the item I'm looking at.
The car has an aftermarket InterState battery that may not have a vent attachment.
Not good... you need a vent.
Depends on  the battery type.  The old lead/acid batteries needed to be vented.  Thus the clear plastic hose.  The newer AGM type batteries do not have a vent.  My current Duralast AGM battery does not have a vent.
