I bought the cheapest Porsche on Craigslist and the IMS bearing has failed
I bought the cheapest Porsche 996 on Craigslist (as a non-runner) and I think the IMS bearing has failed.  The car is a 2002 911 Carrera Coupe.  It has 101k miles on the odometer.
I pulled the filter, opened it up and found ferromagnetic flakes (see pics).  There are also ferromagnetic flakes in the filter housing and in the oil that I drained out of the filter housing.
How likely is it that I can save this engine?  Am I better off buying a used engine?  If the engine can be saved I'd like to rebuild it myself.spacer.png
Rebuilding the M96/97 engine is not for the faint of heart or budget; specialty tools and knowledge are a necessity, and just returning it to factory spec can run you $15K in parts and machine shop time.  You can source a running engine usually for less than $5K.
Thanks for the advice.  Can you suggest some reputable places that might have a good running M96/03?
Yes, this engine can be "saved" and rebuilt better than what the factory offered. But it all boils down to what YOU want to spend to make it right. Basically, you must learn the three Rs of Porsche M96 ownership as it applies to your current situation:
1.) Rebuild it
2.) Replace it
3.) Resell it
Check with your local PCA chapter, and do some searching.  Engines occasionally show up here, but you need to find one closer to home, you really don't want to be shipping one of these all over the place.
44 minutes ago, Andy Ericksen said:
Once I source a new (used) engine, do you have any recommendations for what to do to 1: inspect it, and 2: prepare it prior to installation in the car?
The answer to that question is almost endless:  New IMS, new RMS, new AOS, new low temp thermostat, new water pump, etc. etc...…..
JFP, you have given me a lot of good advice.  I have one more question: Most of the used engines I'm seeing online come with a 30 day warranty.  What or how should I check/inspect to decide if the engine is 'good' before installing it?  In other words, is there anything I can do to be relatively sure the engine isn't going to fail right after putting money in a new IMSB, RMS, AOS, T-stat, etc?
Run a leak down test on the engine, bore scope it, pull the sump cover and oil filter looking for metal like you have already found,  look it over carefully for external damage, check the engine number on the sump rail to make sure it is what it is supposed to be (not a 2.5L masquerading as a 3.6L).  You need to also be careful what year the engine is as major systems changed several times (DME version, fuel system, communications protocols like the expanding use of CAN bus technology for the sensors to communicate over in later model years, etc.)
While just about any year will bolt in, not every year will connect to your chassis and communicate properly.
You actually might check out Porsche NA.  I have heard that they are offering short blocks for $7500.  You transfer all your existing engine stuff over to a brand new short block.  You will want to have the heads professionally rebuilt, and replace the major/minor stuff already mentioned.  If you are going to farm out the work, expect somewhere in the $15-18K range for a complete job.  I believe these guys are the best head rebuilders out there, and you should maybe find out from them about an entire engine rebuild https://www.hartech.org/
No wait...that's not what I was thinking of.  I'll  go look it up on the head rebuilders...something H....
Hoffman  www.hamheads.com
Of course the ultimate builder is Flat 6.  About a year wait....
Edited by DBJoe996
Thanks for the tips.
