Hello,
I have the same problem, I have imported this care from usa and the code did not follow the car!
Becker CDR 220
type BE 4362
serial # Y5022291
Thanks for your help.
Vegar
Try 2700
or
2698
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
I changed the Alternator and went to put the code in. I now realize I wrote down the model number, not the code. D'oh!
Becker 1
Type 4362
Ser: 15031576
Thank you for your help
Mitch
Try 0323
or
0321
Becker 1
Type 4362
Ser: 15031576
Mitch
Try 0323
or
0321
Loren,
0323 worked!
Thanks for the quick response.
Mitch
Ah yes used boxster with no code for the radio, or documentation of any kind.
Type 4462
Ser 15086357
24/99
Gal1 00
cdp2081
Loren,
Bought CDR-220 with no code, could you help?
4462
Serial #: X5018719
Try 1145
or
1143
Thanks for checking, but 1145 and 1143 did not work.
hi thanks in advance need help with code
Becker cdr22
serial no: 15045409
need the code please
model :BE4467
long bar code no: 4467ci015045409
If you have not already read the FAQ - please read it at the link below and follow the instructions...
Try 7162
or
7160
hi read the link shud have read it earlier wud have saved me removing the unit lol
any way tried 7162 & 7160 also tried 7164,7166 & 7158,7156 no luck
serial number is 150 454 09 can you please double check human error can happen to the best of us lol ...
other wise its off to the decode shack few miles away ...
many thanks Zak 996(2001)
HI EVERYONE update on radio code turned out it was 7163 not 7162 ??
you sir are a rock star :D
hi there, i need some help with my code,
cdr-220
model # be 4462
serial # y5048549
thanks for any help :)
Try 1800
or
1798
Worked perfectly! Thank you so much!
Hello,
I have a CDR-220:
Becker 1
Type 4462
Serial #: 15076720
Thank you in advance,
-Berz
Try 4613
or
4611
