  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
I tried 6848 6846 6850 6852 6844 6842 should I try odd numbers?
Did you get the serial number from the display sequence (per the FAQ)?
Sure try odd numbers, if you have the patience.
Hi Loren:
Absolutely awesome site!
CDR-220
2001 996
Becker 1
#4462
S/N Y5046379
Thanks so much in advance
Sure enough! it was one off from the code calculator but it was odd not even.. maybe a good suggestion for the 5% that don't work( to change from odd to even or vice versa). Thanks
hi all. long time lurker, first time poster.
2001 S
cdr220
s/n Y5061176
thank you!!!
Try 8386
or
8384
thanks! i'll give it a go!
The first one worked great! Thanks again. What a relief.
Another lost soul here who just purchased a Porsche/Becker radio/cd unit without the code, to replace the existing cassette radio. The info on the unit is CDR 220, Model Number (BE 4462), Serial Number (15086889) Can anyone here help me out as I understand that there is a way to get it.
Thank you in advance for your help as I am going to try to install it for my wife before she gets back from her trip to NY as a surprise for her birthday.
Try 3133
or
3131
My battery crapped out on my 1999 996 Carrera 2.
CDR 220
Becker 1
Type: 4462
Serial: X5031852
48/98
Can you suggest a code? Thanks, I can't believe you do this, apparently, non stop. Bobby in Jax
Edited by Bob Kahle
CDR 220
Becker 1
Type: 4462
Serial: X5031852
48/98
Try 6867
or
6865
Ah yes used boxster with no code for the radio, or documentation of any kind.
No Go on radio Code for either number
Type 4462
Ser 15086357
24/99
Gal1 00
cdp2081
Try 2972
or
2970
CDR22
Type 4467
Ser Y5028991
24 99
TIA
W
Try 7657
or
7655
Thanks for that Loren. Tried both with no luck. Just waiting for the 60 minutes to expire to try the '2 rule'. Many thanks for all your help - you really are #1...
W
