  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Battery died and need radio code:
CDR-210
BE2262
SN: T5000744
Try 2609
or
2607
Neither of those codes worked. I may have been wrong about the model number - it reads out R2896 on the display. Would this change the suggested codes, or are they based on the serial number only? Thanks again.
CDR-210
BE2262
SN: T5000744
Try 2609
or
2607
Where did you get your serial number? off the radio or through the serial number display? or?
CDR-210
BE2262
SN: T5000744
Try 2609
or
2607
I got it off the display.
Hmm... you can try 2 digits sequences each side of the number I gave you... or you will need to call a dealer.
Okay. Thanks for all of your help!
One more for you. I need the radio code after unhooking my battery to do a mod to the door panel. Thank you for doing this for everyone! It's a kind deed indeed.
2002 Boxster
Becker 1
CR-220
4362
SN# 15001981
24/99
2002 Boxster
Becker 1
CR-220
4362
SN# 15001981
24/99
Try 5067
or
5065
Loren......I have a 98 Boxster with the CDR 210 and will be disconnecting the battery for some work soon. I have not seen any codes for the 210....any help? Thanx
Page 12...I may have them ...are they relatively universal?
Edited by stcroixdrew
To get the (best guess) code for your CDR-210 we will need the serial number from your radio.
You can get it electronically displayed through the front panel or pull the radio out and read it off the back.
Such a prolific thread!
I was going to try a few of the codes already posted but there are so many and I see no real pattern to how the codes are assigned.
I wish to add my request for a a radio code:
Type: 4462
SER: X5023871
Curious is the "48/98" numbers a build date?
Type: 4462
SER: X5023871
Try 6639
or
6637
Ha-ha, thank you very much Loren unfortunately those did not work and I used up all my attempts repeating one of them just to make sure, so now I am in "Wait" mode. I'll attempt the +/- 2 variation when I can.
I really think it is a sign I need to just step up and put a new HU and speakers in there, the CD transport mechanism stopped working properly nearly a year ago. :D Cheers.
Loren,
Can you help me with a radio code. I have a 1998 Boxster with a Becker CR-210
My vin # is WPOCA2989WU623990
Your VIN does me no good - I need the serial number of your radio.
Where do I find that. I can not get the unit out without the funky keys. The serial number on the back of the face plate is 208012515382071409
Please scan/read this thread as getting the serial number to display is described a few pages back.
How about...
cr210
R3297
V5008293
Thanks Much...Long trip home without music
How about...
cr210
R3297
V5008293
Try 5416
or
5414
How about...
cr210
R3297
V5008293
Try 5416
or
5414
It was 5416! Thanks Much Loren!
help help help hi could you please help me my stereo locked up after i changed the battery. its a 2000 boxster 2.7ltr and im in australia. thankyou so much.
type - 4462
serial - Y5035729
Edited by mrgrant
hi sorry to say but another very desparate person who changed batterys and lost there stereo code
becker
type 4462
Serial - Y5035729 THankyou soooo very much, life is awful with no music.
becker
type 4462
Try 4875
or
4873
