Hi Loren! Just bought a used 996 and of course radio is locked...
Becker 1
Type: 4362
Ser: X5010610
45/98
thanks! -g
(FWIW it looks like a premium audio package... tape deck in dash, CD changer + amp in trunk)
Try 4369
or
4367
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
One more quick question: is the signal seek switch the scan button? Does it matter if you push up or down to enter?
You can download the Becker Owners manuals here.
The 2000 Boxster came with 2 radio cards and neither is correct!
Becker 1
Type: 4462
Ser: 5037168
Thanks for your help!
Me too -- paint shop . I got the radio code card from the original owner, but it's blank. I feared this day would come.
2000 Boxster
CDR 220
model # 4462
ser. # Y5042991
Thank you very much for the help
Jef
Try 4957
or
4955
Neither worked, plus 4956. I confirmed the model and ser. numbers, they are correct. Also, I checked to see if an LED (LEDs?) is out such that what appears to be a "Y" is really an "X." Looks like it's really a "Y." Shall I run through numbers close to the two you suggest? What else?
TIA
Got it -- 4951.
Loren, please know that as an additional way to say thanks, I'm renewing my contribution.
Becker 1
Type: 4462
Ser: 5037168
Try 0518
or
0516
Very kind of you, Loren. 0518 worked right away. Arrigato Gozaimasu
Hi Loren,
I just replaced my battery and my CODE # 4679 that came with the deck is not working.
CDR 220
VIN# WPOAB29942S685235
SERIAL # BE 6625 1 5002956
Any other code i can try?
Cheers!
Frank
Edited by calfrank
Hi Loren,
CDR 220
Cheers!
Frank
Try 4677
or
4675
Tried both 4677 and 4675 and no luck. Any more suggestions?
Is there anyway I can check the serial without pulling out the deck? I'm giving you the serial based on the card that came with the car i bought.
I appreciate your help.
Hi, hope this is enough info for a code search:
1999 Boxster
Becker CDR-210
W 5022942
Thanks for any help !
Gary
Try 0981
or
0979
Hi Loren, had to go + 2 up to 0983 to get it, but I've got tunes again !! TYVM !
Loren -
If you could please look up another radio code. Preparing to install PNP speaker kit, did not get a radio code card with the (used) vehicle; although "1268" is hand written on the option sticker under the hood. Would like to verify before proceeding.
2002 Boxster 2.7
5 speed manual
US
Becker CDR-220
Type 4462
Serial # 15005474
Loren -
2002 Boxster 2.7
5 speed manual
US
Becker CDR-220
Type 4462
Serial # 15005474
Try 1266
or
1264
Sorry Loren. Just got the info from the car:
4462
Serial # X5017370
Thanks again! =)
Try 2886
or
2884
Hi Loren,
I tried 2886, 2884 and 2882. None of them worked. Any other one i should try?
Frank
4462
Serial # X5017370
Thanks again! =)
Try 2886
or
2884
Hi Loren,
Frank
You did not read this did you?
Lost Radio Code - FAQ -- PLEASE READ THIS FIRST
Yes i did, but thought you might have other ideas. Thanks anyways, I'll call the dealer tomorrow.
4462
Serial # X5017370
Thanks again! =)
Try 2886
or
2884
Hi Loren,
Frank
:lol: If I had any other ideas I would put them in the FAQ. Sorry...
I just bought a 2000 Boxster S and of course the radio is locked
here's the info , any help would be really appreciated.
Becker 220
4462
Y 5037878
Try 2855
or
2853
Need Radio Code Please for
2000 BOXSTER
CDR 220
TYPE 4462
SER# X5035348
24/99
Edited by Loren
Removed ALL CAPS - please do not post in ALL CAPS
Hi Loren -
Would appreciate your help on getting my radio code. I moved my car to Europe and don't have radio card. Battery was disconnected for shipping - I forgot to check code before I left.
2000 Boxster 2.7
5 speed manual
US
Becker CR-220
Model BE4362
Serial # X5017793
Many thanks in advance, and appreciate the service you provide everyone here!!
Kerry
