my friend tried those codes,no dice also, thank you for your help
any others?trying to not call the dealer lol....
I think you are stuck calling the dealer.
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
actually codes were correct,had them all along,but in my case.......after entering the code i press "volume up" button.....and walah...it worked just for your info
Hi Loren,
Hoping you can possibly recover the code...
Type: CDR-210
Serial #: V5006673
Model #: BE 2282
Porshce part #: 993.645.120.01
EC: 103
Thank you for your help! Can't wait to have a functional radio in the car after 9 mos. without!!!
Craig
Hello Loren,
I have the same problem.
Becker CDR 220
type 4462
serial # X5038198
Your help is graetly appreciated!
Thanks Loren, but somehow the correct code came out as 9410. Appreciate your efforts though.
For the serial number that you gave me?
Did you check it through the display procedure?
I am not usually far off.
First I want to say thank you in advance for your help. It is very much appreciated!
Becker CR-220
Type 4462
Serial Number Y5052990
Also says 24/99
Once again thank you for your help!
Tony
I tried 4949 - Nothing
then 4947 - Nothing
and finally 4949 again and just got the "Wait".
Not sure it matters but the car is a 2002 Boxster S.
I really appreciate the help. Do you think it needs to go to the dealer?
Regards
Tony
Becker CR-220
Type 4462
Also says 24/99
Tony
Try 4949
or
4947
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Broke my 1999 C2 cab out of hibernation only to discover I do not have the radio code!
1999 C2 cabriolet tip
Becker CDR 210
Type R 3297
Serial # W 5024623
Any help would be most appreciated.
I should have read your instructions better! I tried 4951 which worked perfectly.
Thank You!
Tony
then 4947 - Nothing
Regards
Tony
Becker CR-220
Type 4462
Also says 24/99
Tony
Try 4949
or
4947
