Going to have some work done that may involve disconnecting the battery, I think it maybe a good idea to have it just in case.
My serial number is WSO18669, thank you ahead of time. Oh, and it's a Becker CDR-210.
Try 9928
or
9926
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Okay, I just recently disconnected the battery, and after reconnecting, I tried both of those and they don't work, perhaps my serial number is actually W5018669? Would that yield different results? The digital display makes it weird to decipher the serial number. Again, thanks in advance!
Hello Kojiro
Your serial number is showing as
unrecognised.
Please remove your stereo from the dash
and post the serial number printed on
the label or stamped on the metal casing.
Post the details here.
Cheers.
Edit:
Sent messege to friend regarding
SN provided, not showing on my system.
Friend reckons code should be 9513 for SN provided.
Failing that, previous comments apply.
Edited by Bruce2010
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi: Just replaced battery and radio is locked! Please help with code; 1999 Boxster with CR220 Serial # W5003014
Thanks VERY much in advance
Try 8727
let me know how you get on.
Cheers.
Try 8727
Cheers.
WORKED!!! Thank you, thank you. Saved a trip to my awful Porsche dealer.
Hey guys,
Greatly appreciate your help on this - new battery, no radio!
2001 996TT
6 speed, black, USA
CDR-220
Serial: 15089074
Edmund
Try 9928
or
9926
Get the real serial number using the procedure in the FAQ.
Try 9928
or
9926
Ok, those are two numbers that come up for me.
You can try add or subtract process mentioned in the FAQ or perhaps Bruce2010 has a number for you...
All these years, finally lost my radio card and a radio key set! The Becker 1 is Type 4462, Ser. No. 15063894, 24/99.
Where might I get a new key set, too?
Try 6823
or
6821
Amazon sells the keys - don't pay over $5.50
http://www.amazon.com/dp/B001684WEU?tag=renntechorg-20&camp=14573&creative=327641&linkCode=as1&creativeASIN=B001684WEU&adid=05PDFVG7DYZRKS2HJ9E7&
I have a 2002 996 TT, Becker 1, 4462, sn. Y5043212. Installed a battery yesterday and get nothing but a WAIT message on the radio. The code that came with my car says 8291 but it didn't work.
Use code 8 2 9 4
Switch your ignition key to the 'ACC' position
'accessory position' where battery light shows
on dashboard.
Power up radio - leave undisturbed - without
touching any buttons. (Touching any buttons will
reset timer from beginning again)
The radio will reset allowing for another code
entry.
Refer to FAQ for further information.
And... let me know how you get on...
Cheers.
Hey guys,
2001 996TT
6 speed, black, USA
CDR-220
Serial: 15089074
Edmund
Try 1905
or
1903
Cheers Loren, 1907 worked for me. Thank you!
