Hi, I hope someone can help. I just had my car painted and they disconnected the battery and now I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated.
Becker
*2140G
type grand prix
BE2140V5209074
Eko
Becker 2140 was not used by Porsche - it was used by Mercedes and BMW.
You can try 1907 but I have no idea of that will work.
Thanks bro, its work. Thanks alot
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
I have code 1076 on dealer $25 911 c4 2000 pcm 1
I dont possibility to charge number 4 on display (fixed )
turn right buttom no number change !! push * on number code
how to charge nuber on display
Thank (sorry for my english)
QUEBEC CANADA
QUEBEC CANADA
Only dealers/OPCs can look up PCM codes.
Please read this FAQ...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
QUEBEC CANADA
Thank Loren I have code "1076"
my question is where process to insert code in my radio
only number 4 on display
Thank
Thanks in advance for the help......
I have a 2002 C4 Cab with a CDR 220, 4462, #25016467.....Please send any possible codes.....
Hello Loren, my battery was reset as well. I would really appreciate it if you could help me decode the radio code. The info is below:
Becker CDR-220
Type:4462
Serial #: W5005292
1999 Porsche 911 Carrera
Thanks in advance,
Mandy
Becker CDR-220
Type:4462
Serial #: W5005292
Thanks in advance,
Mandy
Try 9058 .....
Hello,
I just replaced my battery. I would really appreciate it if you could help me with the radio code. The stereo information is listed below:
2002 Porsche Boxster
Becker CDR-220
Type: 4462
Serial#: 25012241
Amit
Just replaced battery, can I get radio code? CDR220 Model # 4462 Serial # X5023868. Thanks!!
Try 7616
That did the trick!!! Just punched in the 4 digits and the stereo started blaring!!! Thank You!!!
Hello,
Becker CDR-220
Type: 4462
Serial#: 25012241
Amit
Try 2301 ........
Hello,
Becker CDR-220
Type: 4462
Serial#: 25012241
Amit
Try 2301 ........
Thanks a lot Bruce!!! 2301 worked PERFECT.
Inherited a CDR-220 from a friends '02 Boxster that I want to install into my '77 VW Bus. I have ordered the wiring harness from Becker but need the radio code.
TIA
Dean
Date or Manf. 03/02
Accession No: 0110580
Typ: CDR-220
Model No: BE6625
Serial No: 25010993
12v: EC:102
Porsche 996.645.126.10
Bar Code:
*6625AF02501993*
TIA
Dean
Date or Manf. 03/02
Typ: CDR-220
Model No: BE6625
Serial No: 25010993
12v: EC:102
Bar Code:
*6625AF02501993*
Try 8939
Becker CDR-220
Type:4462
Serial #: W5005292
Thanks in advance,
Mandy
Try 9058 .....
Thank you! Worked perfectly! :)
