  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
CDR-220
Type 4462
Serial 25014726 (Z50147526? It looks like a 2 on the display, and I haven't pulled the radio to check the back)
Please read the Lost Radio Code FAQ for how to double check the serial number through the display.
If you think you read it correctly then
Try 1304
Thanks Loren. Finally needed the code today, and unfortunately 1304 doesn't work. Serial #25014726 was read off the display as described in the FAQ, I was just unsure because most serials seemed to start with a letter. Is there another code I can try?
CDR-220
Type 4462
Try 1304
I used the later one (ending 7526).
Using Serial #25014726
Try 5041
I've got a 2002 Boxster with a Becker CDR-220 that lost power and is locked. Ser # Y5035496.
Tried 1544 and 1444 from an online tool, but neither worked. Sure would appreciate your thoughts.
Try 1454
Try 1454
Thanks for the help. Worked perfectly.
Help! Need code for 1997 Boxster
CR-210
Becker
R1996
Serial V5004664
Thanks for any help!
Try 0961
Thank you! It worked perfectly. Appreciate your time and assistance.
@ teeerex .... your code 8789
@ SValdez .... your code 4308
Works :) Thanks very much - as always this site is THE resource for Porsche fans :thankyou:
