Greetings! I seem to have the same issue- my battery went dead and I lost my radio. I followed your instructions to find these numbers- thank you SOOOO much!
'97 boxster
5-speed
radio style CR 210
model R1996
serial #Y5001844
Thank you again much for your help.... I miss having tunes!
Aloha...
Thanks Loren. Unfortunately the numbers aren't working. I got the "code" sign, pressed the number in, then pressed the "up" arrow... and nothing..... just the "code" sign again. Any other words of wisdom?
I appreciate your help so much. It's amazing how many people you've saved from car-silence!!! =)
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
I am a goof ball. If it says wait does that mean I entered the right code?
Cdr-220
4462
Y 5039107
24/99
5753 and 5751 did not work. Tried 5755 and 5759 no dice.
Called several dealers and they all said either the magic number system was down or that Porsche was no longer allowing this to be accessed directly by the dealer. One dealer wanted me to come in for an appointment so that they could email Porsche and wait for a response and test it out.
then it occured to dopey me to call the dealer who originally sold the car (in service records).
Gave them the VIN# and they pulled the file. They said the code number is 0434.
PORSCHE Boxster 2000
CR-220/CDR-220
Model# 4462
Serial # 25015874
24/99
Thanks in advance
I just bought a 1999 Boxster and I need the radio code. The dealer put a new battery in and the code card is not in the car. I would really like to listen to some music.
Here is the info,
CDR-220
Serial # X5021245
Model# BE 4462
48/98
John
I hope someone can help. I would appreciate if someone could help me locate a radio code for my Porsche, the information for which is as follows:
Becker
Type 4462
X5008769
48/98
Thank you,
Chuck
Hi sorry to bother you but i just bought a boxter and need my radio code
its 1999 boxter
4462
cdr220
w5006364
Edited by barrybean
CR-220/CDR-220
Model# 4462
Serial # 25015874
24/99
Thanks in advance
Here is the info,
CDR-220
Serial # X5021245
Model# BE 4462
48/98
John
Try 2522
or
2520
Becker
Type 4462
X5008769
48/98
Thank you,
Chuck
Try 5129
or
5127
its 1999 boxter
4462
cdr220
w5006364
Try 3028
or
3026
sorry they both never worked and my bad i have given incorrect information
it is 4467
30/98
w5006364
becker1
thanks
Thank you VERY much!
Hi....im from germany...the same problem....lost my radio code for my BOXTER
Radio CR 210
Mod R 3297
Ser Nr. V5008018
Please Help.....
Radio CR 210
Mod R 3297
Ser Nr. V5008018
Please Help.....
Try 1143
or
1141
its 1999 boxter
4462
cdr220
w5006364
I tried the codes you gave me and they didn't work. Do you have more codes?
Thanks again,
John
its 1999 boxter
4462
cdr220
w5006364
Thanks again,
John
did u try with these above details
I have a 2001 Boxster with the locked up radio code. Already tried through Porsche with VIN#. This is what I've got:
CDR-220
4462
x5026230
Thanks for any help!
CDR-220
4462
x5026230
Try 4788
or
4786
CR-220/CDR-220
Model# 4462
Serial # 25015874
24/99
Thanks in advance
Here is the info,
CDR-220
Serial # X5021245
Model# BE 4462
48/98
John
I tried the codes you sent (2522 or 2520), the didn't work. So I tried as you suggested, going up and down from the numbers by two digits. After three hours, no dice. I read more posts from the past and read that some people tried single digit moves and were successful. I tried 2523 and BINGO !!!!!!!
I am enjoying music in my Boxster. Thanks again for the code and reading past posts does give a lot of insight. This is a very informed forum and I am learning a great deal about my car.
John
I feel like such a rube. Disconnected battery diagnosing CEL and MAF issues. Lost radio code. Thought I had remembered it. :>(
Boxster 2000
cdr-220
type 4462
serial # X5036971
24/99
Thinking it is in the area of 7271...been trying alot of combos with no success.
What is you spin on the possible radio code possibilities?
Thanks in advance...lesson learned in writing things down.
