Hi, owned the car three weeks.  Came back from the shop and needs the radio code which I didn't get with the car.  Becker 1 CR 220 type 4362 SER (no alpha prefix) 15005073.
 2002 Carerra 2 Cab.
Many thanks.
Try 9323
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Wow, my battery died on my 2002 Boxster and I changed it in less than one minute hoping that the radio has a capacitor that will hold the power.
PLEASE help me with the radio code for Becker CDR-220 Serial Number 15004140 Type 4462.
Much appreciated !
Ghitalu
Much appreciated !
Ghitalu
Try 0864
Thanks a lot, I'll try your code once the WAIT message goes away. Does the engine need to be continuously ON for one full hour or the sum of all ON cycles going forward needs to be one hour ?
Hello, just bought my first 911 and I am loving everything but not having a radio because it is locked. Can I get the code please? Model is BE2182 serial is W5011780 thank you!
Try 2708
Just bought a used 911 and disconnected the battery only to learn the hard way that I needed a radio code, hoping you can help!!
Becker CDR 220
type BE 4462
serial # 15000108
Thank you
Rob
Becker CDR 220
type BE 4462
serial # 15000108
Thank you
Rob
Try 4548
Hello Loren, seems you've helped many in the past. I hope you can help me.
Had my lock cylinder changed as it was broken. Guess the disconnected the battery and I can't find the radio code.
It's a 996, radio is a CDR 210, model 3297, serial W5024701.
Mark
