40 minutes ago, Loren said:
When you turn it on it says Ferrari correct?
It still uses different software.
Yes it does say Ferrari when I turn it on.  I will have to phone the main dealer.  Thanks anyway.
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hello -
Please help me with the code after installing a new battery to my 96 993.
CDR-210
Type: R2595
Serial : S5000460
Thanks very much!!
7 hours ago, momopooch said:
Hello -
CDR-210
Type: R2595
Serial : S5000460
Thanks very much!!
Try 9870
HI, I have a 2001 Boxster with the disconnected battery issue looking for a code for my Becker 1 stereo
Type 4462
serial # y5050879
24/99
Please SOMEBODY help me find the code so I dont have to be a sucker at the Stealership for 190.00. Thanks
Type 4462
serial # y5050879
24/99
Try 0859
2 hours ago, Loren said:
Try 0859
Thank you very much!! It worked. I will definitely donate some of that 190.00 I would have had to spend at the Stealership, to people that are actually enthusiasts about Porsche that like to help people for the betterment of human kind if you know what I mean. Kudos to you guys and the web page for all the good you do.  God Bless you
Unfortunately I have lost the radio code for my Porsche CDR 22 radio when my battery was disconnected.  Any help would be appreciated.
Thank you.
Becker 1
type 4467
# Y5026677
24/99
Thank you.
Becker 1
type 4467
# Y5026677
24/99
Try 0685
I need the Radio Code for my 2002 Boxer Becker CRD-220; serial # 250 14 700, I would be highly appreciated...
Edited by Mike Perez
Double request
Try 4843
CDR 22
BE 6621
Serial Number 25006311
Many thanks in advance
Although would it be possible to get a code for a 1999 996 Sat Nav unit ?
3 hours ago, Karry Terra said:
CDR 22
BE 6621
Try 9020
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
46 minutes ago, Loren said:
Try 9020
Thank you very much
My 1999 porche carrera 911 needs a radio code please help.  Here’s the radio information:
type:4362
ser:w5003205
Becker 1
type:4362
ser:w5003205
Becker 1
Try 8238
Hi, I need to get a stereo code for Becker 1 Type 4462 SN Y5050076. I'm the proud new 5th owner of a 99 Boxster!!
Thanks V
Thanks V
Try 4192
2 hours ago, Mike Perez said:
Hi, I misplaced the radio code for my 2002 Boxer S; Becker 1 Serial # 50 18096, it would be highly appreciated if provided, ...
Try 5353
Still not sure if I'm posting in the one thread.  However, I don't have the radio  code for my:
02 Boxster
Becker CDR 220
Type 4362
serial # 15003133
Much appreciated.  Don't mean to be a pess.  Thanks
02 Boxster
Becker CDR 220
Type 4362
serial # 15003133
Try 0494
