Switch Wiring - Dash Lights Voltage
I'm experimenting with some spare switched, can anyone tell me what voltage I need to apply where to get the dash lighs to light up on a power window switch out of a 99 Boxster? The back looks like this http://www.whiteson.org/boxster/mods/obc/spoilerswitch2.pdf if it is wired the same what would I apply where (out of the car) to get it to light up?
Thanks, Chris.
Thanks, Chris.
The power window switch contact connections are configured quite differently compared to the contacts on a 996TT spoiler switch. In addition, the dash lighting (LED) polarity requirements between pins 3 & 5 are reversed because the LEDs' anodes are connected to pin 5 and the cathodes to pin 3. To further complicate things, whatever polarity voltage you connect to pin 3 for the LED illumination (normally ground), will also appear as an output on pins 1 & 2 when the switch toggle is not depressed. I don't have a power window switch diagram made up similar to the one for the spoiler switch, but if I do create one, I'll post it, or e-mail it to you. In the meantime, perhaps Jeff or Loren can post a switch diagram from the circuit diagrams manual.
Thank you both, so, to light up the switch I need to apply the voltage across pind 3 & 5, I tried this and confirmed it works. However, does the shared configuration with pin 4 mean that is will be impractical to use this switch for the OBC hack? I know that the OBC switch operates by grounding the connection from behind the console, but does this carry 12v? I don't really understand how or why these pins are connected in the diagram.
Chris.
  • 14 years later...
Hi All, I know this is an old thread ....I did the OBC hack using 2 window switches and everything works. I  just can't figure out how to get the night illumination to work. I jumped switched voltage(switched on when lights are on) from an adjacent switch going to pins 3 and 5(neg and hot) the lights work but then the switch loses it function. It only works when I have the hot (switched hot)to pin 5 and move my ground over from pin 4 to 3. Then 1 switch is lit and functions cant remember what the 2nd did. Can anyone help. Thanks V
Edited by vza
It depends on the internals of the switch because they are not all the same, the standard hack uses a FWL switch which has the same problem with illumination. Unless you want to modify the internals of the switch, the only solution is to use a different switch.  You can look up the internal wiring of the switches in the Bentley Manual, you want one that is internally identical to the convertible top switch.
I recently updated my OBC hack that used the FWL switch with a convertible top switch to allow night illumination.  You just need a small flathead screwdriver if you want to swap the top of the switches.
