Click here to Donate
atmorris
Upgrading the sound system - overhauling the speakers
Aha,  that makes sense lol. I'm new to looking round Renntech.  Knew there must be a reason I couldn't find it,  now where is my cheque book
Cheers, Shane
Share this post
Link to post
Hi @JFP in PA
Being a bit of a dunce here,  I am now a contributor,  albeit only from yesterday so not sure just how quick it registers,  but I still cannot see anything to download,  am  I really being that dumb lol
Cheers
Share this post
Link to post
1 minute ago, JFP in PA said:
What are you trying to download?
For arguments sake,  if I go to the first post in this thread & follow the link to the tutorial,  the op has said,  "wow,  2600 dwnloads"  my problem is I can't see the bloomin link lol
Cheers mister
Share this post
Link to post
21 minutes ago, motosparkz said:
Cheers mister
I have restored the missing PDF file.
You can download it now.
Share this post
Link to post
OK, go to the first post, and click on that link (in blue), that will take you to another page, scroll down near the bottom and you should see another link to a PDF file (again in blue).  Click on that and you should see/download what you want.  :beer:
Share this post
Link to post
Fantastic,  thank you.  At least it wasn't me being a bit doolally
Cheers mister
Share this post
Link to post
 Hi again,
 Looks like the link was missing,  Loren fettled it,  I don't feel so dumb now ,  thanks again
Share this post
Link to post
Hi Loren,
So, quick question. I have seen a few tutorials with missing files that I was interested in. (giddy new Boxster owner lol) Can I use the "report this tutorial" or is that aimed at a different thing.
Cheers, Shane
Share this post
Link to post
Yes, you can report them --  but I can only restore items that were deleted from RennTech.org not from outside links (like photo sharing services and the like).
Share this post
Link to post
That is a nice write-up!
I am buckling up a major Winter project on my 2000 986 (2Din head unit,996 cluster, OBD, piggyback Alarm system).
Audio
I attached some pics of the speaker direction I went in as choosing speakers was my top priority.  My decision process was to :
1) Determine what speakers sounded best , and would fit
a. Prepare the car for the auditions (remove head unit, install rear speakers / wires etc)
b. Wire a home theater receiver to the speakers for the testing
c. Install speakers and listen
2) Now that I decided on speakers, choose amp
a. Determine if factory amp (actually now 6x40, same specs) could work with mods
b. Test with HT receiver "line out"  for proper levels
I tested about five different car speakers. None did it for me, I really liked the Dayton RS100-4 but they were too tall,too heavy. I wound up fabricating a substantial mounting mod to make them work. These are the testing prototype pics attached.  I used 1/16" plywood  for the adapter ring and the housing from the original speaker. The problem with using a speaker like this is that they are much heavier than an auto speaker. So, I basically potted the entire assembly in epoxy for strength, drilled the 6 mounting holes needed for the Dayton, and put it in for final measurements. I have a full 1/4" clearance everywhere and they sound great!
More as I have time to write. Next, I will post my mods of the factory amp(s).
Jerry Prado
Edited by Jerry Prado
Fixed
Share this post
Link to post
Everyone.  I apologize to everyone who posted questions that I did not answer. I posted this guide to help out others, but don't really monitor it that often.  But to answer some of the questions in a general kind of way for future posters I can offer these comments:
What speakers you use has less to do with the car and more to do with your tastes. As long as you use decent quality stuff, properly matched to your amp(s), and of the correct size the end result should be as desired.
I did this mod as stage 1 of a 2 stage project. I did initially just replace the speakers,with 4 ohm Polk Audio units. I had retained the Becker CDR23 and the stock M490 Harman amp. But the stock amp is terribly under powered, and the CDR23 didn't support an ipod or USB drive so I had always  planned to replace them both from the get-go.  Amp wise, IMHO, you need 75W RMS per channel, or better, in this car to have sufficient headroom (acoustical) when the top is down.
As far as the door template, Cassiebox beat me to posting a template, although I did explain, in detail, in the tutorial the steps I went through to make mine. Still, Cassiebox's  template is pretty much the exact same thing that I did so that template is all that is needed.   :thumbup:
You can get it here: https://www.renntech.org/forums/applications/core/interface/file/attachment.php?id=7789
I never posted a "replacing the amp" guide because, as I found out,  it is really a fairly complicated, and highly personal, project. Possible mounting locations are found inside the front boot, in the back boot, behind or under the pass seat, or even under the pass side dash. It all depends on what you can manage to do yourself, or pay to have done, and where YOU want things and don't want things.  Initially I located mine in the front boot in one location, then found a few years later, after that amp had failed,  that I had to mount it's replacement in a completely different way (that was a lot more involved.)  Just be careful about drilling the surface behind the spare tire as the gas tank is located immediately behind it.  :excl: I chose to eliminate that surface as a possible amp mounting location for that reason, but I have seen others use it.
It makes this effort very worthwhile to see how much the article has been used by others, and the comments made showing appreciation for the time invested. I hope it continues to be of use to Boxster owners for years to come.
Share this post
Link to post
I just purchased a 3 way component system ( J L Audio C-5)  Ive read several posts about using stock speaker boxes with some mod's, and the sound or output was poor?.  I like the idea about the mounting plate and or baffle you posted.  Two questions if you dont mind.  Do you need to wrap sound deadening around the entire baffle and is it needed behind up against the actual door.
Next, how is the actual sound that is produced?
Thank you in advance.
Share this post
Link to post
