Leaderboard
Popular Content
Showing content with the highest reputation on 02/02/2018 in all areas
  1. I kind of expected this; your pump looks like it has been overheated. People forget that the pumps are cooled by the fuel around them, so consistently, or even purposely running the car very low on fuel can lead to this exact problem. And by-the-by, this issue is common to all in tank fuel pumps, not just Porsches.
    1 point
  2. Yes, a lot of things need to be removed. You may also need to LOWER the engine (not dropping the engine). Support the engine bottom and remove the engine mount nuts, then you can lower the engine by a few inches and that creates all the space you need to work on top of the intake manifolds.
    1 point
