Leaderboard
Popular Content
Showing content with the highest reputation on 09/02/2025 in all areas
  1. 1 point
  2. Hi..I live in rainy Ireland and this has been a real problem in my 996 Cab. I brought your water drain diagramme to my garage and they removed the interior side panel to find an easy solution. A number of drain tubes collate into a collection point like a mini funnel which had built up a pot of sludge and water could no longer flow through same and out of the car...so diverted to the back foot wells. Who thinks up the stupid systems??
    1 point
  3. Today I did front final drive gear oil change. This DIY will show you how I did it. Since I had a hard time to access the drain plug, I removed fill plug and used a pump to suck out the final drive oil. Worked really well, and helped avoid messy drain, which puts oil onto the lower axle carrier frame too. FSM calls for change quantity of 0.42L, and I managed to remove about that much from the drive, so I feel confident I got it all. Used empty oil can go suck old oil into it, and another empty oil can to put same amount of new oil it, making sure I fill with what I removed. I actually filled the new oil can with maybe 1/4" more oil, to accommodate for some oil that pump cannot take out of can, and some oil left in tubing. Oil used for change: Mobil Delvac 1 full synthetic gear oil 75W-90 (direct cross reference to Shell TF0951 - factory fill oil) Oil refill quantity: 0.42L (bit less than half a quart) New fill plug part number: N 902 818 02 Fill plug tighten torque: 25.8 ft/lbs Fill plug removal tool: ratchet, extensions (at least 6"), 5mm hex socket, shop towels Look at this DIY before you do the change. Make sure you have all materials and time to do it. Expect about an hour to hour and a half to complete. Let us know if you have comments. Thank you.
    1 point
