Leaderboard
Popular Content
Showing content with the highest reputation on 09/09/2025 in all areas
  1. That's trouble. Recheck connections. Use Deoxit on the plug-in connectors. Use fine grit sandpaper (and clean off the grit left by sanding) on the nutted connections. Is it possible you shorted something out as you removed the battery? Were the battery cable ends removed at the battery? Is it the original alternator? It might be possible that it's only the voltage regulator module.
    1 point
  2. Your alternator is not functioning, running you should have 14.5V DC. Pull the alternator, check the wiring connections to be sure they are tight and seated, if they are you are in the market for a voltage regulator..........
    1 point
  3. I'd start with checking the alternator, is it putting out 14.5 V DC at idle? If not, I would check to make sure you properly reconnected the wiring.
    1 point
  4. What are your voltages? Resting, idling, driving above 2000rpm? There are gizmos to help with this monitoring - Antigravity Batteries has a battery tracker. Others plug into the cigarette lighter. Do you have any codes (can be read with Durametric and other (OBDII) readers)? I've read stories on Rennlist about induced electrical noise in the sound system even when the sound system is not turned on. Might your alternator be damaged or no longer have a high quality ground? Could the noise be mechanical (transmitted noise)? You did change pulleys. Run the car a few minutes without the serpentine belt and see if the noise is reproduced.
    1 point
