Leaderboard
Popular Content
Showing content with the highest reputation on 02/20/2019 in all areas
  1. 1 point
    LONG STORY SHORT,,...My entry and drive system went bad one day., after almost a year of testing , replacing the battery, buying the test tool, almost brought a china piwis ,.... and bringing it to dealer and 800 dollars of dealer time., I had it fixed for 5 Dollars in parts. and one hr of soldering at first my kessy do not communicate to the darmatic tool or PIWIS at all, the dealer went ahead try to replace it , with a superseeded module, HOWEVER they wasn't able to program it for unknown reason, there is no module out there that will take my car's pin and complete the marry process because they said all the module has been superceeded. The dealer offer me to replace ALL the module in the car to an updated version for a cheapo $3000 dollars.! OF COURSE I refused,. ...,. I only lost my alarm horn , entry and drive function and its not worth $3000 dollars,. I was investigating myself trying to see what causing the problem, I came in to the touareg forum and found out those guys there have a lot of the problems with their module too. ... I was like ,hum.,,. then go under my dash and found the kessy module that is EXACTLY the same as theirs including the part number (WHICH IS A VW part number stamped on a sticker btw).... there is one guy there that took his module to a local electrician and found he has 2 fried mofset and 6 fried resistors.!!! I was like, fxxx it, why don't I give it a try, at first I couldn't found the 0.22ohm resistors (its was HARD trust me I took almost 2 months looking for them)., so I went ahead replaced the two mofset........... 15 mins and a lot of smoke later....... MAN,,,... the module can communicate with my Durametic tool...! HOWEVER,, all the antennas are reporting short to ground ERROR!!! I tried to clear it but the code come back instantly. then I went on to test the resistor value,... and found all six of the 0.22ohm resistors are SHORT (they are fusible resistor btw)....,,. sooooo I tried my best and finally able to locate those 0.22 ohm resistor .., fast forward 2 months later............ I received those resistors today.............. another 15 mins of smoke and sweat with my resoldering station... I plug the module back... run the scan tool clean the fault codes!!!!................... moment of truth,, I plug my dummy key in to the key cyclinder with the real key in my pocket!!!!!!!!!!!!! turn and the CAR STARTS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have successfully fixed a $3000 dollars repair (that don't guarantee will work) with 5 dollars worth of resistors !!!!!! NOTE: IF your kessy don't communicate with the scan tool,. Its the TWO MOFSET that is Fried. if you have all antennas short to ground or not responding its the 6 resistors!
  2. 1 point
    Posting this here for a future reference.... I recently had to replace my ignition switch (2001 boxster s), all of the data online shows the steps involved with working in a cramped position with one's head under the dash trying to get a tiny flat-tip screwdriver into position. That really brought out my claustrophobic demons for a dusting when I was trying to maneuver into position, even though I managed to achieve a really good back stretch. Yet I couldn't get the screws loose that were holding the switch in place. My ultimate solution: Removing the headlight switch assembly and the single screw supporting the heating duct against the backwall. It seems like more work, but it is really easy to do and it makes loosening the two screws holding the ignition switch in place a breeze to loosen from a more comfortable upright position. Hope someone benefits from this tip.
  3. 1 point
    Now, let's get to how we can all prevent water intrusion in the first place...
  • RennTech.org Store at Amazon.com
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
