  1. Every month Excellence Magazine has a market update on different models of Porsches. Find someone with he latest issue that includes the 1965 911's and they will give you a good valuation of where the market stands for each model. The current June 2005 issue covers 356 cars so you will need an earlier issue.
  2. The first thing I would do is remove the headlights (see your owners manual) and look to see if any of the connecting pins have pushed back into the socket and are not making a good connection. I've seen that happen before but it was usually just one light. Litronics have two connectors so check them both. Also check the sockets on the car harness for the same problem. That would be four total connectors per light.
  3. You will need to get the code(s) to help pinpoint the problem.
  4. See step 5 here. When you reinstall, torque them to 22 ftlb. (30 Nm ).
  5. P0117 Engine Temperature Sensor - Below Lower Limit A fault is recorded after a debounce time of 0.4 seconds if an engine temperature of less than -42 °C is measured. Fault conditions - Short circuit to ground. Fault area - Wiring, Temperature sensor, DME control module. P1130 Oxygen Sensing Adaptation Area 2 (Cylinders 4 - 6) - Rich Threshold Fault conditions - Fuel/air mixture is so lean that sensing has reached its rich threshold. Fault area - Intake air system leaking, Fuel pressure too low, Volume supply of fuel pump too low, Fuel injectors fouled. Since you only got a P1130 I don't see how it could be the MAF. Fault P1130 is only affecting one side of the engine and the MAF should affect both. I would fix the temperature sensor then reset the codes. IF the P1130 comes back then start looking for an intake air leak.
  6. Laguna Seca, Monterey, CA -- 92 dB @ 50 ft. Infineon Raceway (Sears Point), Sonoma County, CA -- 103 dB @50 ft. and someone told me Lime Rock, Lime Rock, CT is only 85 dB!
  7. Yes, it will work fine on the a 3.6 or 3.4 liter car. That is one of the "newest" part numbers.
  8. Covers all Carrera, GT3, TT / GT2 and Boxster cars Here is the long explanation from the service manual on the flashing coolant light. "Four functions of the coolant warning light: 1. Engine coolant level too low -- light flashes slowly (0.5 Hz) 2. Engine compartment temperature too high -- light flashes slowly (0.5 Hz) (engine compartment blower might be faulty) 3. Engine coolant temperature too high -- light is lit; pointer on the right 4. Temperature sensor at water outlet faulty -- light flashes rapidly (1 Hz) ; pointer on the right Note: The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously."
  9. I wonder if that was damaged in a previous repair? Like a an RMS repair where they take the transmission out to get to the RMS. Hmm... :unsure:
  10. I think you are talking about the only mount at the rear of the transmission. There is no single part listing in my parts list either. It looks to to be pressed in at the least.
  11. Where can I order the cable and the software? www.obd-2.com
  12. Have a look at TSB 6/98 5737 Inner Door Release Inoperative (dated 12-17-98). Sure sounds like your bowden cable is either broken or disconnected.
  13. Loren, I saw the review but did not see the tool itself. Do you have a model number and/or purchase place? This one is not a tool per se - it is software and a cable. You load the software into a laptop computer and then plug the cable into both the laptop and the OBD II port on the car.
  14. Have a look at TSB 3/00 7059 Noises In The Door/Door Trim Panel Area (dated 6-30-00). I think "Complaint 2" on page 4 is what you want.
  15. Actually if it is in the differential -- some parts are available for the differential (bevel gears, pinions). I would not expect more that them splitting the labor with you. If you are lucky they might cover all the labor. MSRP for the transmission is $9511.30.
  16. The one I use with my laptop is reviewed here.
  17. Interesting enough the bumpers themselves are the same part number but the spoiler lips are different part numbers. I'll have to look closer at them side by side sometime. Perhaps the TT spoiler is a little longer? The u-clips can be reused if you don't bend them taking them off.
  18. A GT3 engine is based on the TT engine not the Carrera M96 engine. They are very different. The manifolds on the GT3 have 3 bolts per cylinder and the Carrera's have 2. I have never tried the GT3 mufflers or cats on a Carrera but I doubt they would line up right since the manifolds and engine position are slightly different. My advice is forget about GT3 exhaust parts and concentrate on the sound/performance you want from a Carrera exhaust.
  19. Stan, You have checked everything except the horns (and the connection at the horns). It is a simple circuit - each horn has a ground wire (brown) and the share the power wire - that is, the relay actuates both at the same time. So, if you measure the voltage at the black/yellow wire coming off the relay panel you can be assured that power is going to the horns. At that point you have no other choice than to remove the front bumper and check the horns. Removing the front bumper is really only a 15 minute job. When you put the bumper back on just remember to not tighten the screws fully until it is aligned with the hood and fenders (sides).
