  1. Try 8538
  2. Try 5087
  3. Most likely a hose but best look for damage in the radiator too. You may be able to see it by removing that front tire and wheel well liner.
  4. Try 0720
  5. Basic sound, BOSE, or Burmeister sound? As of 2006 wiring diagrams are only available in PIWIS.
  6. Try 1084
  7. It is always helpful if you tell us the exact model and year of your car. Wiring diagrams are model year specific.
  8. Best check the ignition switch.
  9. Correct - totally different engine and exhaust.
  10. Try 0760
  11. Yup, here it is with the clutch slave cylinder (22). I would start with clean fresh DOT4 brake fluid. Bleed both the brakes and clutch. See the DIY here:
  12. Check for leaks and if you have not changed the clutch/brake fluid in the last two years you should.
  13. Try 0792
  14. When spring gets unhooked (or breaks) the pedal goes to the floor.
  15. If trhe gas pedal is all the way to the floor then it could be the spring on the throttle return has broken or is off.
  16. Try 8340
  17. Did you use the procedure in the Lost Radio Code FAQ to get your correct serial number?
  18. Try 0621
  19. Please read the Lost Radio Code FAQ and follow the procedure there. This topic is now closed.
  20. Try 9379
  21. O to 150 ft-lbs should cover most. Nice to have an inch pounds wrench also for smaller fasteners.
  22. Try 0763
  23. Try 6414
