  1. Part Number: 996 512 988 00 Spoiler. It comes unpainted in black plastic. Porsche recommends a 3 mm bead along the full length of the spoiler They use 999 915 400 00 Adhesive Polyurathane... which looks like a black epoxy to me. They also suggest to tape it in place (once positioned correctly) and clean any extra adhesive immediately. Let dry (with the tape) for 12 hours. Obviously you get one chance at positioning so make sure you measure and mark where it goes.
  2. Yes, that price included a sports alignment (usually $120). I can't speak for Scree but I take all my cars to Custom Alignment for tire mounting, balancing and alignment. Perhaps I was quoted a lower price because of that? Why don't you talk to Joe Silva (the owner) and ask him why his price is higher than RennWerks?
  3. 5 minutes to change... 55 minutes to hook up the PST2 and make sure they were right :huh:
  4. NEW FEATURE -- NEW FEATURE -- NEW FEATURE We have added a new feature to the site that allows you to to keep a list of your Porsche(s) mods, upgrades and improvements. It has an easy to use interface that you can add and delete any aftermarket changes from your personal list. The new feature is located on the right side of the small menu that takes you to Help, Search, Members etc. and it is called "Registry". This is THE place for members to document their mods and to view other members mods. You will no longer need that long list of mods in your signature -- now you can have link to your mods. Use this handy link let others view your mods anytime -- anywhere. Enjoy
  5. If your car is MY02 or newer then the upper console comes off in one piece. Use a butter knife or something that will not scratch on the sides. The lighter has a little lock on it
  6. I think the radio is a separate problem. There have been a number of reports of CDR-23's shuting off on their own and losing settings. Even some replacement radios do the same... looks like Porsche needs to sort out the new MOST network system (IMHO).
  7. To my knowledge you can buy one from any dealer (willing to order it for you). Independent garages ususally get a small discount but it is still pretty close to $8000. The software is upgradable with a yearly subscription (for a CD) for about $2500/year. You will need a laptop to transfer the updated software to the PST2. Be aware that there are still specific functions on the PST2 that you will not be able to use without authorization from PCNA (one time codes). My understanding is that some of these have to do with legal reasons (i.e. VIN or mileage changes, door lock codes etc.) and some have to do with warranty. p.s. Where are you located? I'd love to get my hands on one of these for a few days... ;)
  8. You can try and reset the calculating circuit by disconnecting the battery for at least 2 minutes. If you go longer than five minutes you may have to reset the radio etc. If this doesn't work then their may be something wrong with the gauge or sending unit and will likely need a dealer with a PST2 to diagnose.
  9. Ha ha... don't ask a California guy about snow... Porsche actually recommends the 17" wheel and a little narrower tire for winter. They recommend the Dunlap and Pirelli Winter Sports tires. I usually recommend 285/30 x 18 rears and 225/40 or 235/40 fronts. In all cases you will want a wider front wheel if you go with wider tires. These tires will run fine on Porsche wheels (i.e. no rubbing) but if you have 7.5" wide front wheels you will see even more understeer -- not good. If your car is pre MY03 then you can upgrade the front wheels to 8" and put the car back in it's original balance. Your speedometer will have very little effect (< 0.5%) with these new tire wheel combinations. I got my 8" fronts from Wheel Enhancement (with my S03s already mounted and balanced). They have an exchange program so it wasn't like buying new wheels outright. Another good place is TireRack.com and they can ship your tires to any local installed (on their list).
  10. Two questions: 1. Is the light flashing? If so, only the dealer can reset it. 2. Is the light on (solid) but the gauge registers correctly?
  11. I like the SO3s. The Contis worn too fast and never had good adhesion. The Pilot Sports had good stick but squealed too easily and had some road noise. I think the SO3 is good all-around tire. Great stick, low noise and reasonable wear.
  12. Not a PDF but there is an excellent online FAQ. This for a Boxster but the process for a Carrera is the same. Replacing the Handbrake
  13. IMHO... techiques in turns are all out what is beyond the turn. Do you need to let off because of another turn or accelerate down a straight section. There are likely many combinations and with some complex turns you have to try different techniques (i.e. braking earlier and accelerating sooner or braking later and drifting the car at it's limits). There is an advantage to smooth (speed wise) as opposed to upseting the cars balance with a shift or brake action so you may just need to get a stopwatch ;)
  14. I think Gert at Carnewal.com has these complete with all mounting hardware for an excellent price. I know several folks that have gotten them from him. Here are the part numbers (for LHD cars): 996 521 985 01 S30 Left GT3 Seat in Savanna Beige 996 521 986 01 S30 Right GT3 Seat in Savanna Beige
  15. If you are just getting the mufflers installed they default to always open. A muffler only install should take about 1 hour of labor (or you could even do it yourself). If they were installing the electronics that is about a 10 hour job.
  16. Right here in the DIY section
  17. This finish was only offered on Carrera's in MY99 it is called Granite Grey. I call this a no smudge no fingerprint finish. A number of the dash pieces will fit both Boxster and Carrera.
  18. Geoff, You have a number of options including using the earlier "speckle" finish, or carbon fiber or leather or having all the pieces painted.
  19. First I apologize to whomever gave this to me. I try to give credit to those did the work... but I lost the email... sorry Here is the procedure --
  20. Congratulations to (our Moderator) Grant for the article on his classic 73T in the October 2003 Excellence Magazine. :clapping: The article (Carbon Copy) written by Gerry Burger history and creation of this great car. A must read! :thumbup: More photos and a description from Grant can be found here in this thread
  21. As promised... Here is a brief list of New forum features: - Most obvious is the new summary/home page. This page has convenient login, personal message check, search (all messages), and site navigation. It has lists the last 5 NEW messages posted (Latest Discussions) and the last 5 REPLIES (Recent Articles). - A spell checker is now available site wide (including personal mail). - Your mailbox now includes links to your personal mail storage folders. - You can now add a personal photo (linked off site only) to your profile (if you want). - Full text searching available; vastly reduced searching times and improved efficiency. - Fast Reply button opens a Quick Reply box. - You can now do a numbered list (list=1, or list=i, list=a, etc.) for example list=1 would produce 1. Do this 2. Do that 3. Do more, etc. - this should be great for DIY stuff. - You can now add an attachment when editing (your own) post. - Calendar events can now span dates - that is, you can have a 3 day event with one entry. - Clicking on the word "Posted:" in any message will enable you to quickly copy a direct link to any post on the board to share with any other text enabled medium, such as instant messaging software, PDAs, PALMs and even G3 WAP enabled telecommunication devices. Most of the rest of the new features have to do with improved message storage, site speed and moderator options... enjoy!
  22. That part number is for a MY02 or older GT3 so it should fit. Remember that you will need to have a dealer (with a PST2) transfer your mileage and VIN number to the new instrument cluster. This is required by law in the US but I don't know about elsewhere.
