  1. Try 5145
  2. Have you looked for a mechanical fault with the shifter? Sometimes thing fall down into the shift mechanism and jam the lever.
  3. Try 7695
  4. Try 0214
  5. Try 1043
  6. Try 2604
  7. My ISP assures me that their no no country restrictions on renntech.org. The only restrictions are know spammers IPs.
  8. You can try re-programming the PCM and fiber gateway. You will need a "real" PIWIS for this.
  9. Try 8434
  10. Try 4692
  11. Try 2946
  12. Try 9593
  13. Only one rear fog light - by design. Nothing wrong with the rear fog light.
  14. OPC = Official Porsche Center (same as Porsche dealer)
  15. You did not read the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  16. Try 9828
  17. Try 6954
  18. Try 1047
  19. If this is true then leaving the engine compartment open at idle the light should go off.
  20. Bad sensor in the coolant tank?
  21. Sometimes it is further up behind the front bumper. Also something the may help is to have a 2nd person push gently on the front hood log area while you activate the release. If that does not work then you might have to remove the front bumper cover - which means replacing some parts and if not done correctly the front bumper can be damaged. So - good luck on that.
