  1. The smaller the bolt the easier to snap - trust me I have tried the shortcut and failed. Get or borrow a inlb torque wrench.
  2. Try 7434
  3. Try 1024
  4. Try 7172
  5. Try 2986
  6. Try 5243
  7. Try 0982
  8. Try 2154
  9. Try 4769
  10. Try 7184
  11. Try 3401
  12. Try 5940
  13. Try 1420
  14. Try 0483
  15. Try 2780
  16. Try 3151
  17. Try 1963
  18. Try 1716
  19. Try 0980
  20. Anything in the wiring diagrams labeled "TERM 15" is switched power. FYI... TERM 30 is unswitched power. TERM 31 is ground.
  21. Yes and no... Yes if you do not have a proper device to hold it on the bench and No if you do.
  22. If it worked before the steering wheel change and now it does not then that is likely a good place to start.
  23. P1749 Version coding - signal implausible Possible causes: - Open circuit - Wiring - Short circuit to ground - Tiptronic control module
  24. "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  25. You obviously did not read the Lost Radio Code FAQ...
