  1. While they will likely bolt up fine - I have no idea if it will pass smog tests as the later style cats got different O2 sensors. If you decide to try it let us know if you can pass CA smog.
  2. Try 0426
  3. 1. Mount wiper arms on the wiper linkage. 2. The windscreen is provided with points to which the wipers must be positioned. Priority 1 is assigned to the driver's wiper at points C and D . Then position the passenger's wiper at points A and B. 3. Mount the washer 2A and O-ring 2B. 4. Screw on and tighten the fastening screw 2 -- Tightening torque: 24 ftlb. 5. Screw on and tighten the fastening screw 3 -- Tightening torque: 13 ftlb. 6. Close the bonnet. 7. Operate one-touch wiping and check the position of the wiper arms again. 8. Open the bonnet. 9. Press on the cap 1.
  4. Try 0493
  5. Start by reading the Lost Radio Code FAQ Follow the procedure in the FAQ to get your correct serial number. Then post here again.
  6. Try 9090
  7. Try 4303 Thank you. It worked. How do I donate? Art Thank you!
  8. Try 4303
  9. It does not matter - it is an internal timer.
  10. Start by reading the Lost Radio Code FAQ Try 4843
  11. WKD 951 324 06 PCM Operating Manual -- US MSRP $20.04 at your dealer.
  12. Fault code 1673 -- Distance sensor in brake booster Possible cause of fault - Actual value of 'distance sensor in brake booster' is evaluated as implausible (implausible signal) - Short circuit to ground (electrical fault in electric circuit) - Short circuit to B+ (electrical fault in electric circuit) - Open circuit in circuit to control module (electrical fault in electric circuit)
  13. "2. Press together the locking lever on the plug and pull the plug off the flange. Unclip the connection lead at the omega clips. "
  14. No it will not. I have seen an airbag removed from a car and the tech bumped it while removing another part and it fired off. Please be very careful when testing or working on airbags. As I said before without a Porsche diagnostic tool you are just guessing at the bad part.
  15. You really need a Porsche diagnostic tool (PST2 or PIWIS) and a special Porsche airbag tester to safely and properly test airbag circuits. The last thing you want to do it is trigger one or more airbags.
  16. Faults 28 and 31 -- Ignition circuit, side airbag Fault 22 -- Driver's seat belt tensioner Fault 24 -- Passenger's seat belt tensioner Was the car involved in an accident? Did one or more airbags deploy? If so, then the seat belt tensioners will have to be replaced.
  17. The ABS speed sensor (5) is in the wheel hub carrier not the bearing.
  18. For MY2000 Boxster S... 999.053.054.06 Rear wheel bearing -- US MSRP $100.60 This is the latest part number and it has been updated at least four times. I highly suggest replacing both at the same time.
  19. All 5 criteria must be met to have system readiness for smog tests. That includes no pending fault codes. One pending code during a drive cycle starts the process over again.
  20. Try 8740
  21. How to attach images Attachments Depending on where in the community you are posting your message at, you may be able to upload attachments to your message. There are two types of uploaders available: the default uploader and the flash uploader. Default Uploader The default uploader allows you to upload attachments one at a time. To begin, press the button. A box will appear for you to select the file on your computer that you want to attach. Select the file you want to upload. If you change your mind, you can press the button and then choose a different file. Once you have selected the file you want, press Attach the file. If there are any errors uploading the file, you will receive an error message, otherwise, you will see the attachment appear. Flash Uploader You can enable the flash uploader from your settings menu. When enabled, you will be able to easily upload more than one file at a time. To start, press Click to Attach Files. A box will appear for you to select the file or files on your computer that you want to attach. Select the file or files you want to upload. You can select more than one file at a time by holding Ctrl (on Windows) or Command (on Mac) and click on the files. Once you have selected your files and clicked "Open", they will begin uploading. If there are any errors uploading the files, you will receive an error message, otherwise, you will see the attachments appear. Managing Attachments Regardless of which uploader you use, once the files are uploaded you will see them on your screen. By default, all attachments are added to the bottom of your message, however, you can add any attachment to a particular section of your post by pressing the "Add to Post" link. If you wish to remove an attachment and have it not appear in your post, simply press the "Delete" link.
  22. Try 0716
