  1. Try 1017
  2. Try 6596
  3. Question marks do not work for serial numbers - we must have the complete serial number. Please use the procedure in the Lost Radio Code FAQ to get your serial number.
  4. If you gently apply gas do you get the knock? and again on deceleration (lightly lifting)? If so it is likely power train related like cardan or cv joint(s).
  5. Isn't that the mat for the center console storage?
  6. Try 9313
  7. On the menu.. DIY Tools --> Porsche TSBs http://www.renntech.org/forums/tsbs/
  8. Try 4610
  9. Try 8630
  10. Please read the Lost Radio Code FAQ. This topic is now closed.
  11. Please read the Lost Radio Code FAQ. This topic is now closed.
  12. :welcome: When posting it is always helpful to give us the exact model and year of your car.
  13. Try 9816
  14. You are likely going to need a shop with a (Porsche) PIWIS or PIWIS2 tester to scan the car for diagnostic faults. Anything else is just a guess.
  15. I think I would take RFM's advice and clear the codes (see if they come back) before buying any parts.
  16. Have you cleaned the throttle body? If you have not use only throttle body cleaner and do not spray the MAF.
  17. Part of the value will be whether or not it has all the updates. In the case of the 996 service manual there were 99 updates.
  18. Try 6832
  19. :welcome: GT3 shocks are adjustable coil-overs. They look similar to this: Standard shocks and coils have no adjustment and look similar to this:
  20. Try 6751
  21. :welcome: Have you tried "re-training" the window? That is, press and hold the down window until then window is all the way down - continue holding it for another 10 seconds. Do the same for window up not releasing for 10 seconds after it is all the way up. Then test and see if it performs as it should.
  22. Try 9013
  23. Try 5326
