  1. You need to re-train the windows. Hold the down button until it is all the way down and then continue holding for 10 seconds. Do the same for up on the window. Now the windows should work properly and one-touch should be reset.
  2. I don't know for sure I have never measured that. If that P1517 is your fault code then there is only one solution given in the service manual - "perform adaption".
  3. P1517 Throttle Adjusting Unit: Abortion of Test due to Negative Influence on Ambient Condition - Above Limit Note: This fault is only recorded if the adaptation was not performed correctly after the throttle adjusting unit or DME control module was replaced. Possible cause of fault - No adaptation performed The following conditions must be satisfied to ensure that the adaptation is performed: - Do not actuate the accelerator pedal (for instance, make sure that there is not a carpet pressing on the pedal) - Vehicle is stationary - Battery voltage between 10 V and 16 V - Engine temperature between 5 °C and 100 °C - Intake air temperature > 10°C 1. Switch the ignition on without starting the engine 2. Using the 9588 Porsche System Tester ll perform a "throttle adaptation" under the "System adaptation" section (the notes above must be observed)
  4. Sorry, your serial number layout confused me. Try 8537
  5. From the Guidelines/Rules here: "Copyrighted material: By registering here you agree not to post (or link to) any copyrighted material unless the copyright is owned by you or by this site. Repeat offenders will be banned from this site and their accounts, as well as the offending material, will be deleted." This topic is closed.
  6. Those springs a replacement for the original M030 springs in 2009. So, if you documents are not newer than 2009 they could be incorrect.
  7. The inner temperature sensor is located on the right in the plenum panel (at the air inlet housing for air conditioning). 1. Unscrew fastening screws 1 and remove air inlet housing cover 2. 2. Turn inner temperature sensor clockwise arrow and remove it to the rear. 3. Disconnect connector 1 from the inner temperature sensor 2. Installation is performed in reverse order.
  8. That part number is for as MY2003 and newer. I don't know if it will work since there were many changes including the mail ail vent and the instrument cluster.
  9. They are micro-encapsulated (self sealing) bolts - 7.5 ftlb. (10 Nm).
  10. Hmm... Not sure Durametric is right... 997.641.981.35 is the part number for your instrument cluster - which can not cause a CEL or high idle. Perhaps make sure you have the latest software and try again.
