  1. C4S (only) Brake disc thickness, new front 34mm rear 28 mm Minimum brake disc thickness after machining (brake disc must only be reworked symmetrically) front 32.6 mm rear 26.6 mm Brake disc wear limit front 32.0 mm rear 26.0 mm
  2. If you do a search I am sure we've posted the factory settings here before...
  3. Loren- How comprehensive is this information? Specifically if I wanted to have the wiring layout of my car. Is it worth the 110 bucks for the doc or is it vague like a Chilton's manual would be for other cars? In the coming weeks I will be putting in my own stereo and it may or may not be of value to me. What's your opinion? Well, you will all the schematics for your model year car - for $110. If there were any updates later (like there are to the other sections of the manuals) it would cost you another $110 to get them again. For a MY03 Targa you will get 53 pages of schematics that have pretty much all the detail. The schematics contain wiring for all options so if you don't have an option you will have to look closer and make sure you are choosing the right path. Since they have a sample of the table of contents (for free) here is a copy of the TOC for a MY03 Carrera (including Targa). MY03_Circuit_diagram_for_911_Carrera__996__TOC.pdf
  4. http://www.renntech.org/forums/index.php?a...DE=02&cat=5
  5. Yes, for the PSE. Or you can add the switch later (some wiring required).
  6. You are correct. If there is no connection to the speed sensor (Signal A) then the exhaust never gets a signal to close the valves and they are always open. The switch can be wired to be a "manual speed sensor" in the sense that you can have the switch turn the exhaust from open to closed.
  7. The hold-down springs are the same on the Boxster and Carrera - but other parts are not. Those are just hold-down springs - if the old ones are not damaged then I would reuse them.
  8. LOL... my image is from Porsche's Boxster Service Manual. 4 and 5 are the return springs. You just put everything in place as shown and use hold down springs (6) to hold them in place. Center everything the best you can then carefully slide the rotor/drum on. One the rotor/drum is in place it keep everything from flying apart. When you both side done you will need to go through the individual shoe adjustment using a screwdriver through the hole in the rotor. With a screwdriver, adjust the adjustment fixture through a threaded wheel bolt hole until the wheel can no longer be turned. Next, turn back the adjustment fixture through 5 notches again (release approx. 3 notches until the wheel can be turned freely, then release another 2 notches). Repeat the procedure on the other wheel. You should also adjust the cable tension at the handbrake inside the car. You may have to first release tension on the cable to do the adjustment above.
  9. The only thing you can do is see if another car at the dealership does the same thing. If it does then you are likely stuck with the issue. If not, then you get your dealership to change it out - under warranty.
  10. Because all the "00" caps leak.
  11. The spoiler should extend at approx. 75 MPH -- it should retract at approx. 37 MPH.
  12. If you cap part number ends in "00" -- then it needs to be replaced with the "01" version. If your cap leaks (regardless of the part number) - it needs to be replaced.
  13. Maybe if you mix the old (yellow/green) with the newer (pink) you get blue? Tool Pants pic
  14. Check with Jeff Clark at Sunset Imports - I only see a wire harness in the parts list for MY02 and newer. But there are several "harness repair kits". He likely knows which one to order. You can email him at: JeffClark@sunsetimports.com
  15. It is a challenge - a third (or fourth) hand always helps.
  16. Model Year and model please...
  17. I posted the link to the instructions and the full discussion of part numbers 5 posts up. http://www.renntech.org/forums/index.php?showtopic=493
  18. Yes, but you will need to cut the bumper mount back to fit the curve of the TT bumper. This has been covered here many times...
  19. Do you have to have the switch rekeyed to use your existing keys? How hard is it to DIY If you replace just the electrical part of the switch then nothing has to be re-keyed or re-programmed. If you replace the whole lock assembly then you do have to re-program.
  20. You can disconnect the wires and test the lights - but it is likely the switch. It's not hard to replace - just a little hard to reach.
  21. Good to know. Since its new to me I dont need to point out the obvious that I never got a post card. I'm going to have to go back and give them hell since they saw the car last summer. I put the car into service and I'm not seeing a compliance notice. How wonderful. My seal isnt cracked like slb's cap, but I suppose I could investigate the fuel vent. Any quick way to test that? If the seal leaks bad enough it will cause a CEL.
  22. Is there anything on the ICV that needs cleaning on an egas car? I dismantled mine and it looks quite different from the non egas ones. Mine looks like a round disc. I ended up just cleaning the throttle body which solve the problem anyway. eGas cars do not have an ICV. The idle is controlled by small movements of the throttle butterfly - so IMHO it is more important on an eGas car to keep the throttle body and butterfly clean.
  23. Well it is up to you. We suggest the dampers but I've heard of folks reusing them - worst case you will have some squeal. If the sensors turned on the brake pad light then one or more of them will have to be replaced (or jumpered). You would need to look a the pin and spring to see if they are worn.
