  1. Could be PSM or ABS - I think both can cause the light to come on. PSM and ABS work together on the later cars.
  2. No TSBs for that problem for MY04. You could still have a worn strut mount or a loose swaybar.
  3. Your car has PSM not PASM. PASM did not come out until MY2005. Option M476 is PSM. Here is Porsche's glossary description of PSM
  4. So there are no belt tensioners, or other pyrotechnic stuff on the earlier models (a 1999 996 C4 for instance) in the seats ? I am considering to change the drivers seat for a Sparco seat I had in my previous BMW:s, and that I currenlty resting in the garage. On the BMW:s there were belt tensioners and I needed special subframes that had brackets and fixings for metal wires connected to the release handle for the positioning of the seat. I have not been able to find any subframes for the Porsches. Have a look at Brey-Krause
  5. If you have a US car then their are two switches on the brake pedal - one for the brake lights and one for the cruise control. Are you sure you got the right one? Should be easy enough to test with a jumper wire.
  6. Hmm... those lights didn't come on before? Usually the PSM and PASM lights at the same time mean the MAF is not connected.
  7. No... I don't think so. Won't fit a C4S either without some work... http://www.renntech.org/forums/index.php?s...ost&p=22785 http://www.renntech.org/forums/index.php?s...ost&p=23469
  8. Have you tried disconnecting the battery for 5 minutes?
  9. That is the custom in the US -- not in the UK.
  10. 1. With a screwdriver through the top air slot, release the left and right retaining clip A and pull the air vent out of the dashboard. 2. Pull apart the electrical plug connections and remove the air vent. Installation is plug the electrical connections back in - push vent into dash until it snaps in place.
  11. in the uk essex i have considered investing in the diagnosis software though how much is it and where can you get it http://www.durametric.com Price will depend on which package you order. Anywhere from $247 to $597 as I recall. Still, much better than a used PST2 for $3300 - $4000 on eBay... :rolleyes:
  12. Well, I have never seen a MY99 C2 with LSD that didn't also have TC.
  13. Use new fasteners .The header nuts should always be replaced. Exhaust fasteners can hardly ever be reused.
  14. Does the new LED light have instructions? The wire2 should be marked (i.e. power and ground).
  15. It is an LED so watch the polarity.
  16. 1. 999.084.447.09 Hex Nut (3 per side) -- US MSRP $1.17 each (as of January 2007) 2. 996.343.509.01 Bellows -- US MSRP $50.92 each (as of January 2007) 3. 996.343.301.02 Additional Spring (bump stop) -- US MSRP $15.38 each (as of January 2007)
  17. DRL are not standard on US Porsches only Canadian Porsches. Perhaps someone did the hack on your car (pretty easy to reverse) or perhaps your car is a Canada spec car?
  18. For safety (legal) reasons you can not turn off an airbag light by disconnecting the battery. You will need the Durametric Software, or a PST2 or a PIWIS tester to turn off the airbag light. Where are you located? Perhaps there is a member close to your location that can do this for you.
  19. Can you give me some more information about this service bulletin ? I have the same problem but my dealer says he never heard about this problem and the service bulletin. Thank you Philip Tell your dealer to look at TSB 7/05 4075 Noises From Around The Front Spring Struts While Driving -- dated Sept. 13, 2005
  20. That is true since you will be drilling the old hinge mounts. Just keep a vacuum handy and don't drop parts inside the console. ;) We have posted the Porsche procedure: http://www.renntech.org/forums/index.php?showtopic=245
  21. It's not too hard to get to. You will need to loosen or remove the wheel well liner on the drivers side. Everything is there.
  22. How many miles? If it is over 40,000 check the diverter valves for cracks and other hoses.
  23. Model year of your car? US/Canada car or RoW car? 1. The turn signal flasher relay is in position 3 (that would be 3rd from the left. The relays are on the relay/fuse panel on the left bulkhead (next to your left foot if you are in a LHD car). 2. Perhaps off the switch on the brake pedal?
