  1. That would be cylinders 4 to 6 - which would be the passenger side of the car.
  2. BTW... the Porsche RS Spyder won P2. It's first time out. One of the drivers Lucas Luhr said "... we just wanted the car to finish".
  3. Put some more miles on it driving normally. If the battery has been disconnected for longer than about 5 minutes the DME must relearn it's idle and power functions. If it doesn't smooth out I would likely look for carbon build up in the throttle body and idle bypass valve first.
  4. Try locking the car with the door key lock. Then unlocking the same way.
  5. My parts list shows part numbers for the bushings - but it will depend on model year, model, and standard or sport suspension. Give me those and I will get the part numbers.
  6. You have checked and/or cleaned all the major ground straps right... ?
  7. It covers the control unit at the front of your comfort seats.
  8. 996 604 103 00 Starter -- retail $566.10 (as of Oct 2005) Doesn't look too hard...
  9. Thanks to Tool Pants for getting a pic of the new seal!
  10. According to the wiring diagrams - in the front luggage compartment near the battery/firewall. ^^^ Wrong - Sandy corrected me that the wiring diagrams are wrong. It is in the interior. I think Sandy will post a pic.
  11. You will need a PST2 (or PIWIS) and a Porsche code (delivered to a dealer) to lock the unit. I'm pretty sure this is for legal reasons.
  12. Are you sure it isn't 92U (ignore the L) - I think L is for Lacquer.
  13. Phil White has written an excellent article in the October 2005 issue of Total 911 Magazine. He discusses possible RMS causes including improper replacement techniques and has comments from RennTech.org Contributing Member Berny Goodheart (Scouser). Thank you to Philip Raby at Total 911 magazine for allowing us to reproduce this. You can download the PDF version of the article here: Under_performing_seal.pdf
  14. Odd... 996 505 986 92 01C Spoiler lip -- retail $243.63 shows up in my price list
  15. Brown wire with blue stripe needs to be disconnected and taped.
  16. Please PM or email your requests of other members. Thanks!
  17. Not sure it matters since the rate is the same but yes the electrical is long part. The TSB actually calls for 10 hours.
  18. Try doing a search for instrument cluster and or gauges. This has been covered many many times here.
  19. :oops: Forgot the color code - my bad 955 555 102 00 4V8 Right moulding light olive wood (gloss) -- retail $37.57 (as of Oct 2005)
  20. http://www.renntech.org/forums/index.php?s...indpost&p=10388
  21. These come from a different source. I converted then back to the older Acrobat (5) format. You might want to update to Acrobat 7.x - then you can read them all. They should work now.
  22. Not according to the service manual. If it were my car I would likely do the prescribed maintenance 5-10,000 miles early... but that's just me. :rolleyes:
  23. New info from the TSBs (4/05 1359): The full Boxster (986) and Carrera (996) TSBs are available to Contributing Members in the Current TSB section.
  24. Yes, about $3300. PM me if you want more info.
  25. 955 555 102 00 Right moulding light olive wood (gloss) -- retail $37.57 (as of Oct 2005)
