  1. It is a Torx E12 socket. "E" is for External.
  2. You've got a PM...
  3. 996 424 075 01 EKS Gear Shift Knob (original) available stock only 996 424 075 02 ENK Gear Shift Knob Savanna and Silver 996 424 075 05 ENK Gear Shift Knob (MY00-02) Good Luck!
  4. The original ones are only available as "use" stock - that is, only what dealers may have. The silver/leather (not aluminum look) are available as is the version that was used from MY00 to MY02. I will need the color you want to get you the right part number.
  5. Telephone prep connector. On it you will find: +12 volts unswitched (red/green) +12 volts switched (green/black) Ground (brown wire) Telephone Mute Signal (yellow/black wire)
  6. I've added a new section to the OBD II section that gives a table of Porsche System Tester(s) codes and their cross-reference to P-Codes. Useful when the service technican gives use a two or three digit code that is not a (Standardized DTC SAE J 2012) P-Code. This listing is also useful to related P-Codes, to determine fault types and whether the MIL (CEL) light on, off or flashing with a specific code.I think I transferred everything ok but let me know if you see typos or other mistakes.Porsche OBD II P-Codes Section
  7. According to the manual: 27 Oxygen sensing, area 1 Cylinders (1 - 3), P1123 (Short to ground below lower limit/lean mixture threshold) - MIL is on, emission relevant fault 35 Oxygen sensing, area 1 Cylinders (4 - 6), P1125 (Short to ground below lower limit/lean mixture threshold) - MIL is on, emission relevant fault Possible trouble areas: - Fuel pressure too high. - Fuel injector leaking. - EVAP canister purge valve open. I'll try to get the Fault Text table online in the Pcode area in the next few days. It doesn't have solutions but it does show how the codes relate to each other.
  8. If you are looking for factory manuals and they are not supplied by Porsche -- then they are bootleg. There are some third party manuals out there but they are not very good (IMHO).
  9. I think that was on the GT3 ClubSport (M003) only. The same feature is available on the GT3 RS (RoW only). Unfortunately, it is factory installed so no instructions.
  10. Since it is both and flicking the switch seems to help - then the switch seems like a logical choice (as adsach said). Another possibility is that the socket where the lights plug in (inside the fender) may be corroded or dirty. In at least one case I saw where one of the holders allowed the socket to push back when the light was pushed in and the light was intermittent.
  11. Have a look at the 996 DIY here as it is the same process for a Boxster. The Motive is a great little tool for the DIYer. It allows you to put brake fluid in the container and then put pressure in the container so that one person can bleed the brakes and clutch without the worry of getting air into the system.
  12. If I remember right it is an 8 mm allen bolt from the bottom. I think the later cars may have a cap on the bottom that needs to come out first.
  13. Yes, the side panels just pull off. The batwing will come out but sometimes it helps to pry behind it with a butter knife (non sharp prying tool).
  14. The owners manual is available online here. If you are looking for the service manual Porsche sells sections or a yearly subscription here
  15. According to PET - XNG is instrument surround in leather. I think Scouser's list is the one from Kindel and includes most of the old car codes - some of which were reused on newer cars.
  16. My advice (for what it's worth)... 1. Make sure that the tire installer has worked on Porsche's before. Some of these guys look at them and don't have a clue how to lift one. 2. Make sure that their tire mounting machine does not touch the rims. Like a Hunter TC 350 Tire Mounting Machine. 3. Make sure they have a high end Hunter GSP 9700 Road Force Measurement Wheel Balancer or better. 4. Find a good speed/alignment shop. A professional 4 wheel alignment should run about $160. These are usually the folks that do all the race cars in the area.
  17. The parts list only shows it for MY04 - option 220.
  18. He took the clip off (or it wasn't there) that holds the reverse cable connector to the white plastic block. For MY04 a different cable and connector is used as the C4S has LSD. PET shows a special clip only for LSD cars.
  19. Yes, for MY99 options 220 - Locking differential (40%), 222 - Traction Control and 224 - Automatic Locking Differential always went together. The LSD (option 220) was always sold with Traction Control the forerunner of PSM.
  20. This handy little tool is only $9700 to purchase... and of course you will need the monthly updates $1200/year. It plugs into the OBD II socket under dash. For certain functions it has test/measurement probes that are plugged in elsewhere. It can read all of the cars diagnostic systems (DME, instrument cluster, OBC, ABS, PSM, etc., etc.). I don't know for sure what PIWIS stands for yet - I'll try to find out. The older system was the PST2 which stood for Porsche System Tester 2.
  21. XTG - Inner sill finished in leather XTN - Mirror adjust in leather XU1 - perhaps XV1 - Defroster trim in leather
  22. US and Canada cars are the same - not RoW. So, your car is about 20 mm higher in the front and 10 mm higher in the rear than RoW cars
  23. C36 - Canadian version 030 - Sport Supension XSC - Porsche crest embossed in seat headrests X54 - Stainless Steel Exahaust X70 - Door entry guards in stainless steel with logo X71 - Aluminum colored instrument dials X97 - Aluminium/leather shift knob X98 - Aluminium/leather parking brake handle 139 - Seat heating, left 220 - Locking differential (40%) 222 - Traction Control 224 - Automatic Locking Differential 236 - 18" Tires 340 - Seat heating, right 375 - Sport Seat, left 376 - Sport Seat, right 413 - Pressure-cast Light Alloy 18" 'Turbo Look' Wheels 424 - Automatic heating control 425 - Rear Window Wiper 446 - Concave hub cover with colored extrusion 490 - Sound System (w/amp) 859 - perhaps 659? - Onboard Computer 680 -Digital Sound package (DSP) 896 - perhaps 696? AM/FM Radio with CD 983 - Seat Covers in Leather, front 09991 - manufacture from the exclusive-programme
  24. On a 997 it can only be done with a PIWIS - and only dealers or high end independent shops have them.
  25. The "factory" GT3 Mk2 rear wheels are: 11 J x 18 with 63 mm offset. The 11 J x 18 offset 45 mm wheels are for C4S/TT widebody cars.
