  1. Thanks! Spring spacers or wheel spacers? If I may, there is a greart article on Porsche tuned suspension in PCA Panorama. IMHO I think it is kind of a required reading before making any major decisions on suspension changes. You can find the article at: 996 Standard and Sport Suspensions Analyzed
  2. As long as it is DOT 4 (not DOT 3 or synthetic DOT 5) it should be okay. Porsche does not recommend synthetic brake fluids (I do not know why). I change back and forth with ATE Gold (Type200) and ATE Super Blue. This is great for street and pretty good for light track useage. Both have a high dry boiling point (536 degrees) and a high wet boiling point (392 degrees), but without being excessively hygroscopic (these fluids do not readily absorb moisture like most high performance fluids). They are the same fluid with the same properties one is yellowish gold and the other is blue. This allows easy viewing when bleeding to see when the new fluid is through the system. The are other higher temp fluids that are available... but for the most part if you are changing every 3-4 DE's then you should be okay. About $12 liter and you will need about 1 liter per change. Other good fluids are: Castrol SRF Brake Fluid (dry boiling point is at 590 degrees, wet boiling point of 518 degrees) -- Do not mix with any other fluids. You must do a complete flush with this fluid. About $65 liter :eek: Motul 600 (dry boiling point 585 degrees and a wet boiling point 421 degrees) -- Synthetic. Do not mix with any other fluids. You must do a complete flush with this fluid. About $12 liter AP-600 (dry boiling point 590 degrees, wet boiling point 410 degrees) -- Do not mix with any other fluids. You must do a complete flush with this fluid. About $18 liter
  3. Is your car a Targa? I see an extra piece for the Targa (911 511 127 00) but not listed for coupe. I don't remember this on my 76 911S coupe...
  4. Factory spacers should be balanced. They are screwed onto the hub so they become part of it and should maintain the balance. If you are using aftermarket spacers I would be tempted to have the wheel balanced on the car (good shops can still do this when needed). That way the wheel weight would offset any balance issues. All JMHO... as I've never seen one out of balance. ;)
  5. Mike, The Porsche 5 mm spacer kit uses 5 mm longer wheel bolts (911 GT3, P/N: 996 361 203 90). These GT3 wheel bolts are marked with GT or with a red color on the head surface of the bolt head, or the rotating spherical cap is galvanized in red. The distance from the bolt head flange (not the rounded washer) to the bolt tip is approx. 50 mm. The standard wheel bolts, P/N: 996 361 203 00 are approx. 45 mm. I'm sure you can order them separately. 5 mm spacer kit
  6. If you click on either donate button, then when the PayPal page comes up click on the "If you have never paid through PayPal, Click Here" button and it will allow you to use VISA or MasterCard. THANKS! :cheers:
  7. If you put the car in neutral and press the clutch in and out, do you still hear it? If so, it is likely the clutch throw out bearing.
  8. Fuel pressure line? or vacuum line? I emailed you some info on the fuel pressure lines.
  9. Thanks for the site comments... :D IMHO... It's not about bleeding it about changing the brake fluid. High temps can cause brake fluid to break down and absorb moisture. When the moisture in the fluid gets hot it vaporizes and become a gas... not good for braking performance. Depending on the number of hot laps at a DE I would suggest every 2-4 events and DE's are the toughest on brakes. Brake fluid is cheap (about $12 liter) and changing it is only about an hour once you get the hang of it. A lot of folks go back and forth with the ATE Gold and ATE Super Blue that way they can easily tell when they have bleed through the system. Both ATE Gold and ATE Super Blue have the same chemical properties so there is no advantage to one over the other (a misconception by some since ATE call Super Blue "Racing" fluid). There are several other brake fluids on the market so use what you feel comfortable with. If you want to protect your warranty then make sure use a DOT 4 brake fluid (not DOT 3 or DOT 5 synthetics). You won't need a lift (although if you had access to one it would make it faster). You just need to jack up each corner at a time. See my DIY for the exact bleeding sequence and don't forget there are 2 bleed screws on each caliper (total of 8 per car).
  10. Whoohoo! Looks great Don! :clapping: :clapping: :clapping: The crests and silver on the backs of the seats is a super look too!
  11. I agree with Jeff that if the system has not been drained then you don't need to do anything special for PSM or Traction Control. You may want to bleed the clutch though. It is not very hard and you can find details at this link: Brake/Clutch Fluid Change and Bleeding Instructions
  12. Courtesy of Nasa Racer Pete (used with his permission) - posted by Loren Well, there I was...backing into a parking space against a curb and I was in a hurry and I heard it...SCRAPE! One fraction of a second...barely moving. Got out and looked at the rim...OOOOOOWWWWW! Well, no need to fear...I've done this enough times to have a easy way to do home repairs with a few simple items. Note that this ONLY covers light scuffs, this isn't meant to be used to repair a DAMAGED wheel or one where the scuffs cause significant damage to the rim. This is only for those annoying superficial scuffs like happened to me more times than I care to admit. Now there are PLENTY of GOOD services which can do this for VERY reasonable money...most folks will happily do this but I'm inpatient and have the free time (generally) to spend a couple of hours doing this and it REALLY takes the edge off donking my wheels when I know I can simply fix it myself. So if you are interested...here's what you need: I have a can of scratch-filler primer, the WURTH wheel paint and clear (got mine at Performance Products), some paint thinner, Bondo spot putty (or equivalent), sand paper and some 240 and 400 grit sandpaper (if you are REALLY anal...get some 600 grit). Step 1. Clean...clean...clean...and did I mention CLEAN! This is one of the most important steps. Use paint thinner to THOROUGHLY clean the ENTIRE area around the damage...you need to get ANY wax or polish or anything off the wheel...I'm going to remind you EVERY step...I probably end up wiping down these surfaces 10 or more times before painting...if you don’t do this, the rest is pointless. Also, we want to work ONLY on the area that's damaged...don't go nuts and try to paint half your wheel on the car...for this technique to succeed we want to sand and paint the area only IMMEDIATELY around the damage. 2. Sand and Putty I like to START by masking the tire from the wheel...get the masking tape WELL behind the rim. Next, sand the area to a nice "feather" with 240 grit sandpaper and wipe some spot putty on. IMPORTANT...this ENTIRE project will work best if the wheel is in the sun and its a nice warm day...the drying time of spot putty is minutes but if it's cold or damp, this project is likely to not work out too well. Remember...keep your sanding to the IMMEDIATE area around the damage. Trust me on this. So once you've done the first round of putty, switch to the finer of your sandpaper (400 grit in my case) and sand and putty until it FEELS and LOOKS flush. Note that I use the paper wrapped around a piece of wood to make a flat sanding block. It's best to sand with a flat block to get the smoothest finish: Note that up to this point...including waiting 5 to 10 minutes between coats of putty that the whole project has taken about 40 minutes. 4. Masking and primering: Okay, here's where a bit of laziness is going to create an entire new clay-bar project. This metallic paint will GET EVERYWHERE. I'm talking permanently attached to the fender on the opposite corner of the car...mask CAREFULLY and COVER THE WHOLE CAR with a sheet or equivalent. I've used the thick scratch-filler primer and sanded it and put a bit more putty on. Note that this is the first place where I use the NASA technique. Immediately after I spray the primer (or paint) I clean ALL the overspray off the spokes of the wheel (clean rag and paint thinner) and the area around the inside of the rim...I do NOT want to try to get paint to smoothly adhere to the entire wheel! We just want to paint the REPAIR. Only the clear coat will be sprayed without wiping off the overspray. Wait for the primer to fully dry and lightly sand it with 400 or 600 grit sandpaper. 5. Painting VITAL: READ THE CAN...if you try to use this paint in cold temperatures (or in damp conditions) it’s going to be a mess...shake the can for a minute at LEAST and push the spray nozzle as you sweep across and release at the end. This is roughly the distance I used the can from the wheel...I HIGHLY recommend painting some scrap something to get used to the distances and thickness this paint sprays. Now we SHOULD be nearly done BUT (as always) Pete got inpatient and sprayed the clear WAY too soon and lifted the paint and messed it all up. This is NO BIGGIE...take a deep breath, get out your rag and the paint thinner and take it all off. The thinner I used did not eat into the primer so I simply cleaned the wheel (again) and got to respray the silver. Here’s the paint lifting because of the clear being sprayed too soon. okay, fast forward a few minutes...I had to roll the car forward a bit to keep it in the sun and I had cleaned (and let fully dry) the wheel and RE-sprayed the silver. Now I’m using the NASA technique on the silver paint and CAREFULLY removing the overspray: AND here’s the nicely painted wheel. I’m going to not be an idiot and let the paint dry OVERNIGHT (like I knew i should) and do the clear coat tomorrow. (edit June 14, 2004 added local hosting of images as Nasa Racers hosting was down - Loren)
  13. Home Curb-Rash Repair Courtesy of Nasa Racer Pete (used with his permission) - posted by Loren Well, there I was...backing into a parking space against a curb and I was in a hurry and I heard it...SCRAPE! One fraction of a second...barely moving. Got out and looked at the rim...OOOOOOWWWWW! Well, no need to fear...I've done this enough times to have a easy way to do home repairs with a few simple items. Note that this ONLY covers light scuffs, this isn't meant to be used to repair a DAMAGED wheel or one where the Author Loren Category Carrera (996) - Common Fixes and Repairs Submitted 06/27/2003 10:09 PM
  14. Cool! Thanks Don :clapping: I can build all of my former Porsches there.
  15. Duane, Well the board just opened publicly last weekend so it's not quite a week old. We have a few TT members but not a lot yet. Feel free to tell your TT friends. We are also looking for a good moderator for this forum preferably someone with a lot of TT experience. Here is my 2 cents on turbo cool down time... When you drive hard on the track or just a spirited drive through the mountain passes it is always best to bring the car back to "normal" operating temps. This goes for engine oil, coolant, brakes and of course turbos. The last thing you want to do to your car is park it, shut it off and crank the handbrake on. All of these can lead to premature failures caused by excessive heat that parts were not designed for. So it is always best to drive "normally" for a few miles or park and idle the car for 2-10 minutes. How long depends on your cars current temps. For instance after running 20 or hot laps at the track it usually takes my (normally aspirated) car about 5 minutes to reach normal temps. As to turbo timers... that is your call. If you really don't have time cool your car down then I guess they could be useful. I (personally) just have a problem walking away from car with it still running. Hope this helps some... :D
  16. Sure! 914's, 914-6's, 356's, etc., etc., etc. All Porsches are welcome here. If the interest is high enough then we'll give you your forum. Some of us actually owned (and mod'ed) a 914 :D
  17. Thanks to Sandy for this great DIY... (I've done this on my car and it is not very hard to do. The instructions are very detailed.) Sidemaker_mod.pdf
  18. I haven't seen one that looked like it would hit anything. I wonder if it wasn't seated all the way down on the cable connector?
  19. They are the older GT3 swaybars... but I don't have part numbers for the new ones yet so they could be they same. My misunderstanding, I read "coilovers" in the last line and assumed H&R coilovers... my bad. You are correct on the PSS-9 starting at RoW Standard height. So you will likely go at least to RoW M030 height (20 mm front and 10 mm rear). Yeah, no hurry on the radiator... i was just teasing :jump:
  20. Thanks Mike! The RoW M030 swaybars are: Front: 23.6 mm Rear: 19.6 mm The GT3 (old GT3 not MY04) Front: 26.7 mm Rear: 20.8 mm Just remember that the coilovers lower the car (from stock) about 1 inch. That is the at the highest setting. So if that is okay for your driving then there is no other problem I am aware of. You can always go down from there but not up (higher). p.s. Ready for that 3rd radiator yet? :unsure:
  21. Teaching 1. With the ignition switched on, press the "lift" button and move the lifting/sliding roof drive to the "raised" limit position. 2. Press "lift" button again and keep depressed. After around 10 seconds, a complete cycle takes place from the "raised" limit position to the positions "lower - open - close". 3. Teaching of the characteristics has been completed after this process. Note: The "raise" button must not be released during the entire process. In the event of a restart, the lifting/sliding roof must always be moved to the raised limit position first. 4. If the lifting/sliding roof drive should move back in Item 1, then the closing force limitation function has responded (lifting/sliding force drive was taught). The "open" button must be re-taught in this case. Re-Teaching 1. Press the "open" button until the sliding roof stops. Then release the button. Press again until the lifting/sliding roof drive stops again. Then release the button. 2. Press "open" button again and keep depressed. The entire process takes place after approx. 10 seconds: "close - lift - lower - open - close"
  22. Porsche has redesigned the oil seal, the installation tools and re-trained the dealers on proper replacement of the RMS. According to a recent TSB (Technical Support Bulletin) Porsche dealers are now supposed to perform a test prior to replacing the oil seal. The test involves checking the mating surface for the seal. If the fit of the special tool is not tight enough... you get a new engine.
  23. Thanks Darren! Feel free tell others about the site. They don't need to be technical to post here... this site is for both questions and answers :D
  24. When a fixed factory (Porsche) spoiler is added there is a change to the wiring harness to disable that warning. You need to purchase and install (5 min max) the following new harness: 996 612 070 51 Wiring Harness. Technical Details: Check whether there is a jumper connecting pin 2 (which is already jumped from pin 1) to pin 5 on plug X23 of the new wiring harness (connection to the vehicle). If this is the case, the spoiler extended signal will be constantly present at the control module and the warning light of the retractable rear spoiler will not light. (at speeds above 74mph). Connect the plug connection of the new wiring harness to the vehicle. Route the wiring harness along the hood shock to the fan housing and attach it on the rear lid with two (2) fastening clips. Connect the fan and interior lamp plugs. Done.
  25. The kit part number is: 000 044 801 63. It is a kit that normally comes with the Porsche Tequipment Sport Roll Bar to cover up holes after you've removed the seats to install the bar. It includes a couple of nicely made silver painted caps, two large vinyl covered plugs, and a mini version of the pin that secures the center of the seatbacks so that you can reinstall the cap over the center mounting point. About $55 I think.
