  1. It means that if you buy the fuel pump for a MY2002 or newer then it will have too high a fuel pressure and could cause damage.
  2. Make sure the part is for MY2001 and older cars as the fuel system changed to ventless return flow system in 2002. The ventless runs at a higher pressure.
  3. I think that is a good choice. Everyone please be aware this thread is about MANUAL transmission Cayenne GTS. Not many of those in the US/Canada area.
  4. Try 8463
  5. Try 4156
  6. Part numbers can start with any number or letters (they had to run out of numbers someday). i.e. 000, 999, N, 95B, etc., etc. etc.
  7. I have removed your double and triple posts on the same subject - please do not make multiple posts on the same subject. Thanks!
  8. if you have dual exhaust tips use this: 955 111 108 30 Clamp ( dual exhaust tips) -- US MSRP $21.89 If you have a quad tip exhaust let me know as their are 4 clamps and they are designated for left or right sides.
  9. Please post the exact model and year of your car - thanks.
  10. With all due respect you are mistaken. We use the same model numbering/labeling that Porsche uses in ALL their documentation. (click to enlarge)
  11. Is your Durametric software up to date? Best try a PST2 or PIWiS otherwise as the chirp definitely signifies an alarm fault.
  12. Try 8387
  13. It is always helpful to give us the exact model and year of your car. The 996 series had two different cup holders.
  14. We only do option code look-ups for Contributing Members since those require a 3rd party service that we must pay for.
  15. Search is your friend here.... http://www.renntech.org/forums/topic/32595-rear-consoel-removal-for-dummies/?p=172958
  16. You really need to put Durametric or PIWIS on the car and find out what alarm error codes you have. In most cases one chirp means one zone is open and two chirps means there is more than one zone open and/or the alarm unit has a failure.
  17. If that is the only fault you have then the diagnostica manual clearly states: Possible cause of fault: - Camshaft rotor (phase sender wheel) damaged
  18. Try 1092
  19. Please read post number 3 in this topic -- RFM is a retired Porsche factory/field employee and I would bet his solution is correct.
  20. Drain = orange arrow Fill = green arrow (click to enlarge) I have removed your duplicate message.
  21. Try 1063
  22. Please READ the Lost Radio Code FAQ -- and follow the instruction to get your serial number and include the model of your radio here.
  23. Dr. Wood -- Last Active Sep 13, 2015 - 06:45 PM Try sending him a PM.
  24. Try 4820
