  1. AC on? or cold defrost on? Those would also likely cause the fans to run.
  2. Try 6513
  3. Try 2523
  4. Try 0594
  5. Did you read the Lost Radio Code FAQ? I think not... "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  6. There is a specific section of the forum (Lost Radio Code) for the sole purpose of obtaining radio codes, please repost there. This topic is closed.
  7. :welcome: O2 sensors do not cause misfires -they report them. You need to post your fault codes here or everything is just guessing.
  8. What fault codes? or pending fault codes?
  9. The same -- just realize it is likely a few pounds less.
  10. I use Permatex Anti-Seize Lubricant which is a blend of aluminum, copper and graphite lubricants. A thin coating will affect torque settings slightly - but that is better (IMHO) than corroded and rusted on wheel lugs.
  11. You can buy a replacement key - just copy the code on your broken key and take that to the dealer. If you do not have the key a good dealer will try all of their keys until they find the correct one and then order you a replacement. Always good advice to write your wheel key code down and keep it for just this occasion.
  12. Try 4186
  13. Try 9067
  14. I would just clean them up and apply anti-seize paste as Porsche recommends.
  15. :welcome: 996.642.234.02 was replaced by 996.642.234.03 that was replaced by 996.642.234.04 that was replaced by 996.642.234.05 that was replaced by 996.642.234.06 that was replaced by 996.642.234.07. Theoretically any or all should work - but they may need software and firmware updates.
  16. Try 5710
  17. Nine times out of ten - the battery in the sending units is bad.
  18. I think that person is mistaken. Here is a list of Porsche engine and their serial number ranges by model year (under "Remark"). Porsche (and we here) have been using this system for years. (click to enlarge)
  19. VIN is not on the engine or transmission but each do have a model and serial number. The model and serial number can be used to get the approximate date of the build or re-build. Carefully copy those down and then post them here and we can lookup and tell all that we can.
  20. Try 8728
  21. Removing the headlights is covered in your Owner's Manual.
  22. 996 - Common Fixes and Repairs -- http://www.renntech.org/forums/tutorials/article/38-polishing-acrylic-headlights/
  23. Try 0361
  24. The 2001 cluster will likely work if it is re-programmed to your car.
