  1. Try 2102
  2. Try 1094 no luck at all have tried moving up and down by one digit didn't work either is there anything else I can try kind regards momo1212 Did you use the procedure in the Lost Radio Code FAQ to get your serial number? If not, please do and re-post. If you did then sorry I can not help you.
  3. Try 1432
  4. CR-210 and CDR-210 operate the same. Please try the procedure in the Lost Radio Code FAQ. If you get the same serial number then I can not help you - sorry.
  5. 996-341-371-03 Support -- US MSRP $4.37 each You will also likely need 900-380-015-01 Nut -- US MSRP $0.89 each
  6. Try 0597
  7. Try 3062
  8. Try 0597
  9. Fault code 46 -- Central locking synchronisation Possible cause of fault - Short circuit to ground/open circuit between alarm system control module and door locks - Door lock faulty
  10. For your radio try 0572 We do VIN lookups for our Contributing Members (see the Donate button at the top right of any page). Since this is service we are charged for we ONLY do it for Contributing Members.
  11. If it is only the lock mechanisms then it is likely the central locking/alarm control under the drivers seat. Any chance it got wet? If so, you may have a lot of work ahead of you.
  12. Try 7181
  13. Try 0714
  14. Try 7323
  15. Try 4603
  16. Please use the procedure in the Lost Radio Code FAQ to get your proper serial number - then re-post here.
  17. Try 9235
  18. And it has been covered here many times over....
  19. Correct.
  20. Try 6506
  21. Po Please read the Lost Radio Code FAQ for a list radios we can decode. It says that trafficpro radios can have their unlock codes decoded. Did I miss something? Thanks. Porsche TrafficPro only and then I would need the number of preset buttons.
  22. Please read the Lost Radio Code FAQ for a list radios we can decode.
  23. Try 1025
