  1. And I posted your code already here: http://www.renntech.org/forums/topic/14539-lost-radio-code-post-your-request-here/?p=267861
  2. Try 9630
  3. Try 8782
  4. Try 4981
  5. The DIY link for codes is for P-codes - those are engine emissions codes only. Other codes for different control modules are in the Porsche Service Manuals. Start by checking the power and ground as well as the connections. Has the car had any steering or suspension work lately? If so, then these sensors need to be re-calibrated with a Porsche PIWIS tester.
  6. Fault code 0493 Combination sensor Possible cause of fault: Actual value of functions integrated in the combination sensor: • Rate-of-turn sensor • Axial acceleration sensor • Transverse acceleration sensor is evaluated and displays an implausible value (implausible signal). • Internal CAN: Wire faulty (no signal/communication) • Short circuit to B+ (electrical fault in electric circuit) • Short circuit to ground (electrical fault in electric circuit) • Open circuit in circuit to control module (electrical fault in electric circuit) • Combination sensor faulty
  7. Try 5298
  8. Try 0786
  9. And your radio model is?
  10. And your radio model is?
  11. Please read and follow the instructions in the Lost Radio code FAQ. CDC-3 is the CD Changer - we need the radio serial number.
  12. Try 1012
  13. Try 6585
  14. Try 4983
  15. Did you check the car with a (Porsche specific) diagnostic tool for fault codes?
  16. I sent you a PM.
  17. 955 325 039 00 appears to be correct.
  18. The CD Changer is mounted in different locations for US/Canada cars vs. RoW cars. If you have questions please state which car location.
  19. Try 5156
  20. Try 9697
  21. Here is the current listing of fuel system related TSBs (TIs) for your car. I do not see one for the airbox. (click to enlarge)
  22. Go to your dealer - they have a kit so they can try each socket. Once they find the correct one have them order one for you.
  23. Try 1046
  24. Try 0675
  25. We really do strive to be helpful here... so please consider "helpful" comments.
