RFM
Everything posted by RFM
  1. Looks strange to me, GPS use US army satellites as info also in Europe. I have got a couple of weeks ago some rebuild PCM units, all with US VIN numbers still programmed, here to build in European cars without problems after reprogramming.
  2. The PCM have to be reprogrammed with a PIWIS tester to Europe specs in a dealership.
  3. Maurice I'm not confident with Durametric but if you can catch actual values mode, select the O2 sensors, watch the Lambda values and the voltage, the have to pending ( engine hot and idling ). If the sensor(s) stay stick on one value and voltage, the sensor or wiring is defective ( P 0160 ) P 1121 is the heating on the same sensor, P 1117 is the heating on a different sensor ( b 2 ). Usually the wiring is OK, sometimes bad contact in the connector, mostly the sensor defective. Good hunting.
  4. Since you have no diagnostic tool to check the codes and values, i would start with cleaning the throttle body and idle valve, despite the fact that the MAF running strange reactions. If the cleaning have no solution, than replace the MAF or let check in a dealership.
  5. Just pull off, starting on the bottom.
  6. All Tiptronic's shifts, depending the driving style and traffic, early till normal. If you ever prefer that the gearbox stays in the same gear and /or shift to your feeling, use the manual mode ( steering wheel buttons )
  7. Integrated in the accelerator pedal or in a box above the pedal ( controlled by a short steel cable )
  8. Agree with juniinc, if the wiring looks OK, hook up a diagnostic tool in actual values mode, O2 sensors check voltage and pending Lambda values ( P0160 )
  9. This is not a exclusive North American issue, the same here. The country official car importer is not happy with warranty issues if the car is never sold by his organisation, and is matriculated at the same country as the official importer ( car delivered by a parallel importer, which have no work shop and no investments to do in hard ware, parts and personnel or in an other country where the car is cheaper ) They have never earned one cent on the car and have to fix the problems, PAG paid only for the parts and the labor to replace the defective parts and a limited part of the diagnostic labour, the difference is for the count of the organisation or the dealer. I have not the intention to defend or attack persons or organisations but the medal have two sides and in a certain way i can understand their opinion, every body is searching for the cheapest way and/or make money. The European law what concerns free movements of goods tell it different, they have to do the job under warranty and they finaly do, but be sure you are number 101 or higher on their waiting list. Such situations are numerous.
  10. The valve is open all the time the engine is hot, with a cold engine the valve will close, if the metal lock is placed in horizontal possition.
  11. Engine temperature is the responsible data for second air pump as Loren said. ROW cars have the same pump, a switch from USA to ROW have no influence to the pump IMHO.
  12. The broken spring is located on the back side of the door trim, it is possible that the dealer forgot to connect a small connector on the back side of the trim in door handle area, while reinstalling the trim. You can take a look if you remove the trim.
  13. The brake switch is located on the ABS hydraulic group, under the DME right front side of the car, in the room under the plastic trim ( wiper area )
  14. The showed hose is a water hose, what you call crusty, looks like dry and cracked engine protection.
  15. The phone module is the most rear one, full light alloy and mounted upside down ( identification sticker downwards ).
  16. Have the pads the same measure ( especially the height ) as the originals? Is the rotor installed and locked on the hub with the two small bolds? Are the wheel bolts locked with 130 newton ( 13 Kgm )?
  17. Yes, it is possible. In this case you have to check the DME "actual values" adaption values reaching rich threshold ( engine takes false air - same symptom as vacuum hose loose/cracked ), in some cases the CEL will come on.
  18. Check the brake switch to start , this is not uncommon. The switch is located on the brake pedal ( the brown one on ROW 986 )
  19. The car trigger a fault code if the rear or front wheels are activated separately during a certain time and speed.
  20. I never was off road so it is only a suggestion, read the manual attentively, all doors-hood-rear door+window closed? car in complete stand still? brake pedal activated? air suspension in highest possition?
  21. The shifter needs a sign ( current ) from the ignition switch via the brake pedal switch to unlock. Check the ignition switch again ( removed from the lock and activated with a flat screwdriver ) and the brake switch as well.
  22. Why have you not asked what the motivation was ? It should have cleared the situation a little.
  23. gandrade1, do you have already cut out the foam on top of the air filter, it will give you a different intake sound, not as a K & N but you try it.
  24. Is it not possible to let manufacture a new bushing in a specialised shop if the shift linkage shaft is still in good shape ? Must be the cheapest way IMHO.
