JFP in PA
  1. Welcome to RennTech Yes, it has to come out.
  2. If the rack has never been changed out, a VIN search in Porsche parts system will reveal exactly what part number the car came with, as well as any updated components released to the market since the car was sold. VIN based parts searches are by far the best way to do what you are trying to do; and most dealerships will not sell you a part without getting the car's VIN first because they don't want to waste time ordering in or shipping the wrong stuff. It is simply the best way to get the correct part. In all the years I have run my shop, we have not had any problems going this route.
  3. Then the VIN should be good. The two cases I ran into involved a "grey market" car (one that was never approved to be sold in North America and therefore should have never been registered as it lacked appropriate emission and safety devices for this market) and one that was stolen (VIN actually came back to a Honda Accord). Call Sunset parts, ask them to run your VIN to find out which rack should be in the car; parts departments do this all the time. 😉
  4. As you live relatively near Sunset, give them a call and ask them to run the VIN for you 503-718-6060. I all the years I have been running VIN numbers to get parts listing, I have only had the system say that twice, and both time there were problems about the car. Let's make sure the VIN is legit first, then get the parts you need.
  5. You can try running a parts search on board sponsors Sunset Porsche's online parts site, starting by entering the car's VIN which will figure out which rack is in the car.
  6. Sounds like you may have a bad stat that is jammed open, which is better than jammed closed, which is probably what triggered your overheating event. Pull the stat and look at it, if it is open, that is your culprit.
  7. As yours is a five-chain engine, I would be willing to bet that the biggest part of the deviation values comes from worn chain pads located between the two cams on each head. This is a very common problem, but fortunately the fix is cheap parts wise, but does require some labor to get at them. I don't remember how many of these we swapped out over the years, but it was quite a few.
  8. Anytime, that is what we are here for. 😉
  9. Because the flywheel bolts are torque to yield, and are acutally stretched under load, thread locker is not required. The pressure plate bolts on the other hand are relatively low torque spec bolts, so they would benefit from an application of a medium strength thread locker like LocTite blue. In no case should either the flywheel or pressure plate bolts be reused, they must be replaced.
  10. Call me anything but late for dinner................😉
  11. How declutching alternator pulleys work
  12. Manual transmission cars used declutching alternator pulleys, while the Tip cars did not.
  13. Any quality aftermarket metal based, or marine grade anti seize compound will do the trick, Amazon sells them:
  14. Then your AOS is fine. We checked every car that passes thru the shop for this vacuum level, just as a precautionary measure as the cars tend to show higher vacuum levels for a bit before they become problematic and need to be changed.
  15. When contemplating a later model Porsche engine replacement on one of these cars, you need to take a lot of things into consideration, such as: The fuel systems changed year to year, some changes were minor, others not so much. Later engines are nearly totally CAN Bus technology, the early cars had none; over the years, there have been multiple DME changes, some were significant, and trying to use the later engines can turn into and electronic and reprograming nightmare. I could go on, but I think you get the picture. You need to understand just how much will need to be changed to make a possible swap work before you leap into a financial black hole......
  16. First, drive the car for a few min. to make sure it is fully warmed up, then follow this video: How to check cam timing with the Durametric software
  17. Realistically, LN ceramic hybrid IMS retrofits should be good out to around 75K miles. Again, checking cam deviation values and the oil filter for metal grit being present would also confirm the IMS status.
  18. Interesting thinking, but as he has the Durametric software, he could just ask it to check the cam deviation values; if they are +/- 6 degrees, he is good to go on cam timing 😉
  19. As several of these DTC codes point to the central locking system (46, 47, 34) I would say that it points to the central locking/alarm/immobilizer control box under the seat, not the car's central computer (which is called a DME). Several codes also note locking positions not being reached (61), which ties into the car beeping. So, you may have a combination of one of the doors not reaching locked position. and/or a bad central locking control unit.
  20. Oil in any tail pipe is never a good sign of things to come..............
  21. Even thinking about buying one of these vehicles without an totally independent pre purchase inspection by a shop with both considerable Porsche experience and Porsche specific diagnostic tools would be a total crap shoot. A quality PPI is your last chance to avoid a financial black hole............. You would be utterly amazed at what we have found while doing PPI's for customers; the stories would keep you awake at night 😮
  22. The "third design" IMS bearing began showing up in 2005 and is larger than the earlier versions. That said, they also fail, just in not as large numbers as the earlier versions. LN does make a retrofit kit to permit the retrofits of either their ceramic hybrid bearing or the once an done IMS Solution; only problem is that to do anything with the third design bearing requires pulling the engine apart as this bearing is literally too big to fit through the opening in the rear of the engine cases. Once the LN kit is installed, however, any future work can be done without a complete engine tear down. Probably the best and simplest update you can do to an engine with the large bearing it to remove the rear seal on the bearing so it can lubricate and cool with the oil mist circulating in the engine. We have done this on multiple large bearing engines, with complete success.
  23. Unfortunately, these are two separate cooling loops, the temperature of one is no indication of what the other is doing. And I would not suggest driving it any distances.
