JFP in PA
  1. With the Tip trans you have, there is no drain plug, requiring that you syphon out the old oil through the fill plug opening. 996 rear diff oil change.pdf
  2. I sounds like you are getting a "handover" error. There are times when the information or data carried by the CAN (Computer Area Network) communication lines may get corrupted. To repair this there is a Porsche procedure known as a “Vehicle Handover” because there is a good chance that this will repair your electrical/computer related problem(s). This process utilizing the Porsche PIWIS tester basically reinitializes all the computer parameters and controller settings back to what the car had when it left the factory new. It is not unlike rebooting your computer after a crash. To my knowledge, only a PIWIS or Autologic system can do this reset.
  3. Absolutely not a problem. 175-180F is fine for these engines, we have many customers running the same combination at much lower ambient temps and without any issues over prolonged useage. And just as a thought, if your reference to "the secret menu" refers to using the climate control to read the coolant temps, just be aware that method can often generate erroneous numbers. If you want to see confirmable data, scan the car with a Porsche specific scan tool such as the Durametric system.
  4. There are really only a few options: PIWIS, lease only from Porsche, currently around $18,000 (US) for the first year; PST II, outdated (replaced by PIWIS) so it is limited and showing its age, occasionally pop up on the internet for a few thousand $ (US); Durametric, best aftermarket Porsche specific system for the DIY market, runs on laptop computer and sells for about $300 (US) with unlimited future updates; Autologic, very good aftermarket system, but sells for $12-15K (US) and you have to buy future updates.
  5. Loren's point is that the codes you have gotten are cylinder misfire codes, not sensor codes; if any of the O2 sensors were acting up, you would get specific codes for each sensor. The entire point is that you are using a scan tool that you your self describe as "cheap", and obviously not Porsche specific, exactly what many before you have done and gotten misleading code data which then led them down blind diagnostic alleys. Before spending any hard cash, you would be well advised to get the car rescanned with a Porsche scan tool.
  6. Because of your low mileage, I would first bleed and evaluate the slave cylinder. How? Thread, topic, video you recommend? Thx. There is an extensive thread on the subject: http://www.renntech.org/forums/topic/7064-brakeclutch-fluid-change-and-bleeding-instructions/page-1?hl=+bleeding +clutch +slave Normally, most people bleed the clutch slave as part of the brake hydraulic system flush, which should be done at least every two years, sooner if the car is tracked. Both the clutch and brakes share a common hydraulic reservoir in these cars, so it is a great time to flush and bleed both systems if yours has not been done in a while, or if you do not know when it was done last. Not flushing these systems regularly can allow air to build up in the system as moisture collects in the fluid. IF that moisture is not removed, it can actually boil, leading to spongy brake and clutch pedals. The moisture is also absolute corrosive Hell on some very expensive component's in the systems.
  7. Because of your low mileage, I would first bleed and evaluate the slave cylinder.
  8. Just got it confirmed by a Porsche Master Mechanic - same oil. Good to know, thanks.
  9. Just got it confirmed by a Porsche Master Mechanic - same oil. Good to know.
  10. You need to test the circuit for both continuity and correct voltage, but do so with care. Porsche would do it by connecting a hyper expensive "pin out" box to the harness, you are going have to do it using a multimeter across the harness section.
  11. Again, you need to be careful in doing this type of test as even a static discharge from your body can be enough to trigger one of these system. As for your diagnostic tool, while it appears to be a good one, Porsche uses some unique diagnostic systems in their cars which can easily fool scanners that are not Porsche specific (PST II, PIWIS, Durametric). This is a common problem that has tripped up more than one DIY repair.
  12. If it is not the sensor, then as Loren pointed out above, there has to be a fault on the sensor circuit leading back to the control unit. You need to start checking that circuit for correct voltage and continuity (shorts). You also need to do this carefully as this testing could easily trigger the air bag. Disconnect the battery for several min. before disconnecting the sensor and airbag in question, then start testing the harness.
  13. To correctly remove air from the system, you need the use of a vacuum filling tool. While it may be entrapment, it could also be a thermostat issue.
  14. Before ordering any parts, you need to get the vehicle up and verify where the leak(s) are first. There are several potential points where it could be leaking.
  15. Reason I ask is the 1128 and 1130 are commonly occurring code pair caused by an air leak (overly lean mixture condition).
  16. Are you sure the code are P1130 and P1138, or could they be P1130 and P1128?
  17. Don't really know, I've only seen the one spec for the PDK oil as posted above.
  18. Don't really know, I've only seen the one spec for the PDK oil as posted above.
  19. We ain't much warmer here, 20F overnight tonight. Thank God for garage heat..............
  20. Yes, but it is a little more complicated as you need to adjust the fluid level when the transmission fluid is in a specific temperature range. There is a DIY in the 996 section (the procedures are exactly the same for a Boxster) that details how it is done.
  21. I realize that these systems exist for the benefit of emergency vehicles, but I would not want to be around when the local constabulary catches a private passenger car messing with the traffic lights.......
  22. A C4 should hold about 64L of fuel total, it is possible that your gauge is not calibrated correctly as you should be down more that half a tank when the light comes on.
  23. And I'm sure that won't get you in trouble either......................... :eek:
  24. If the car is level, and it ain't running out of the overflow when at temp, you are still low.
  25. That should be hot enough.
