JFP in PA
  1. Please do not double post, it is a violation of forum rules.
  2. Here ya go: Excessive resistance, particularly in the ground straps, is a well documented problem with these cars. Porsche has even released updated cables to address the issue. Some of the cables are not fun to get at, but when they show signs of problems, they have to be replaced.
  3. I am a bit perplexed by "a humming behind the seats" as the fuel pump is in the fuel tank, ahead of the windshield on a 986. Are you sure you jumpered the relay correctly? Silver_TT is also spot on that you could still have a failing CPS and should be checking that as well before buying parts.
  4. Side of the bell housing, the sensor reads teeth the on the back of the flywheel to determine engine rotational position.
  5. And this is where it is and what it looks like on a non Turbo 996:
  6. It should be held by a plastic clip in between the intake runners for cylinders 4 and 5.
  7. The man is getting good at this............................................ :thumbup:
  8. You can make a lot of power out these engines without resorting to blowers or hair dryers. Raby has posted some big numbers for 2.9L engines that are pretty reliable, and I understand he has been working on something in the 3.8L range that is a killer as well. But in either case, he has gone through the entire assembly and relpaced all the weak bits first (rods, pistons, cam followers, cylinder liners, etc.) to make them substantially stronger. Even stock 3.2L or 3.4L are a big jump over a stock 2.5L.
  9. Can also be the crank postion sensor, which causes the DME to shut off the fuel pump. You can pull the fuel pump relay and rig a bypass jumer wire to test the circuit without the relay in place (do a search, has been written up before).
  10. There are no "overflows" on these engines, the oil system is sealed because it operates under a slight vacuum (around 5" of water). It also does not take much oil to make one Hell of a mess. Suggest you need to clean off the engine so you can look for where the leak(s) are coming from. Could be the AOS, the oil fill tube, or any number of other places where actuators or sensors come out of the system.
  11. The 2.5L M96 were know for weak cylinder walls, particularly near the bottom (hence D-chunking). We are not fans of taking any M96/97 above atmospheric for a variety of reasons, and the 2.5L least of all.
  12. Glad you got it sorted, now go enjoy both your lady and all that HP under your right foot.........................
  13. Yes, all M96/97 engines are similar and are susceptible to the same issues, some more than others.
  14. Quite often, the voltage regulator is the issue but fortunately can be changed out as a less than $50 DIY. Car should be showing around 14V at idle, much less than that is an indication that either the regulator or the alternator itself is on the way out. You can usually get the alternator tested for free at auto parts stores.
  15. Another option is to call Gbox and discuss your exact problem(s); the $4,500 gearbox probably needed a lot of work, yours may not. And you should not be focusing on if a repair is recoverable at sale, they often never are; but you also need to recognize the potential reduction in value a bad transmission will have at sale time. If we get a car in for PPI with wonky gear box, we automatically assume the potential "pull and repair" cost as a "deduct" from the asking price........
  16. Depends upon what they find when they examine the innards of the transmission; recent overhaul on a six speed out of a Turbo ran $4,500, but the gear box was right when it was finished.
  17. A lot of people use the "Wal-Mart alternative"; it is just a 35% urea mixture. The easiest way to fill the tank is with the correct bottle, but then that has to be filled from the larger container.
  18. Don't know about that; I've driven a couple of Gbox fully rebuilt transmissions, and they 1-2 shifted fine, cold or warmed up. Granted, not cheap; but I would bet it would be less than the cost of going to a five speed, not including the hit the price of the car would take.
  19. There is only one way, the six converter bolts are removed through the starter opening after removing the starter. They are positioned in three sets of two each evenly around the flywheel. You will also need special tool 9595, which is a 5/16 rod with a knob on the end that is inserted into bell housing and retains the converter with the transmission (keeps it from falling out while removing the trans). This is covered in detail, with diagrams, in the Bentley 996 manual, a worthwhile investment.
  20. AdBlue is supposed to refilled about every 10K miles, or when the dash warning indicates you are running low. Nothing needs to be reset, the system is totally automatic.
  21. There are some "knock-offs" running around at a variety of prices, some are clones of older versions of the software, some are not even a Porsche system (some are even older versions of the Durametric software). Problem remains that even one based on the older PIWIS software is both out of date and cannot be updated with the latest version of the software when Porsche adds new stuff, like the ability to turn off the clutch oil cooling system when servicing the PDK. You have to be very careful when spending thousands to buy something from a Chinese website that Porsche has already told you they will not sell you; you could end up with something questionable and of very limited utility, and with no recourse to get your money back.
  22. Half shafts are different as well, as are the rear hubs, carriers, and ebrake assemblies.
  23. I'm a bit of a "belt and suspenders" person, so I would vote to take a pass on the track time until the car is correct. Perhaps others might want to chime in on this................
  24. Time flys when you are having fun...............
