Anyone know where to get the tools to remove the pins fro the AMP connectors on the DME harness?
Todd
Try the Radio Shack catalog. Pin removal tools should be common items. Sometimes I use a trimmed tywrap slipped alongside the pin to unlock it.
I already tried Radio Shack, however they only seem to have the round pin extractors and were very confused when I mentioned I needed pin extractors for AMP connectors. They thought I was working on my stereo.
Todd
Edited by tholyoak
Todd
ack radio
Thanks for all the suggestions. All of these places have AMP extraction tools, but none seem appropriate for the type of AMP connector I have shown. I was hoping someone had experience with this and could tell me I need a particular set of tools rather than buying a bunch of incorrect tools or spending an hour searching the internet for something that may work.
Todd
try this catalog: http://www.aerocraftparts.com/images/Catal...-Pages20-35.pdf
i believe you want part # M81969/1-02 on page 30.
Todd
Did you try Fry's? I hate those stores, but they seems to have lots of hard to find stuff
Sears automotive tool departments have all kinds of odd items as well, but I never looked for a pin removal tool there
Hi Todd:
I think there is some confusion over your picture, including myself. The pins are not round as I first assumed, but rectangular or blade type, correct? Outpost.com is Fry’s online by the way. Here on the West coast everyone knows Fry’s. Back to the point.
I have not seen a tool to remove the rectangular pins, they are usually used for power applications, and sometimes molded into the connector, if not, there probably is a removal tool, but expensive. A pair of flat end tweezers or bird nose pliers won’t do I assume. I do not know what part of the U.S. you are in, or even if you are in the country. You could try calling Norvac Electronics in Portland OR at (503) 644-1025, they are very helpful, and if you can find an AMP part number on the connector that they could look up, they could tell you exactly what you need. They will probable know with just your description. Here is another bad Web site : http://www.newark.com/jsp/search/browse.js...equestid=224510
Sorry for the confusion, I hope this helps. :)
The AMP/Tyco connectors and pins used by Porsche are automotive metric. The dealer has a set of tools for all the connectors, made by this company http://www.mibostahl.com/. The set is expensive. I have never played with those pins so I do not know which tool you need.
Hazet, Stahlwille, and several other companies also make these pin removal tools that you can buy as a kit or just the tool you need.
Here are some more.
http://www.office-netshop.de/shop/gallery/ART_00062271.html
http://www.tgs-tools.com/
http://www.tkr-tools.de/online-katalog/entriege.htm
Thanks everyone, I think I have found a similar set of tools as those shown by ToolPants made by SIR tools that is reasonably priced.
Todd
I have the AMP and MOLEX removal tool, they are a good investment if you know you will use them a lot.
I also have the specialised AMP and MOLEX crimp tools, expensive but a highly worth while purchase
cheers
Russ
has anyone actually found the right tool (replacing the 9701?)? does the swiss army style one do it? i just ordered a kabelex 1504...$58, dimensionally, it looks to be the right tool. i will know shortly
ok, i will confirm that it does in fact have the 9701 bit...and it works perfectly. in addition it has the twin prong tip as well that works on vw/audi/porsche
but remember to unclick or unlock the pins fron the harness side of the connecter...not the flat face...
I received this tool and it works just fine on all of the different connector pins. For the price, I don't think you can beat it.
Todd
ToolPants
http://www.etoolcart.com/index.asp?PageAct...amp;ProdID=8893
Here
is the link, I found it cheaper on ebay though
Todd
Todd,
I have a 98, love the colors and my audio, would rather mod than replace,
engine: You have done 2.5 Super, 3.4 and 3.6?
Just wondering if there is a thread on your engine mods and experience, and/or, if in a sentence or three,
your opinion:
I'f I'm on a budget, would you recommend 2.5 super or 3.4 swap and why?
Tks,
Tony
  • 3 months later...
I will bring this back to life.
I bought the Sir Tools 9025 - the swiss army knife thing with 12 tools. In the first picture is also the Sir Tools 9701 round pin tool (now discontinued) that I bought years ago, as a reference for the picture. The 9025 has 5 round pin extractors. I have not yet tried to use the 9025. There are different style connectors used by Porsche so I will have to see what style connectors are covered by the 12 extractors. However, the 12th is a joke - just a flat blade screwdriver bit.
There is also a Sir Tools 9024. Same swiss army style but with 6 exactractors. The poor quality picture is from the internet as I do not have this tool. But I can see from the poor quality picture that at least some of the 6 extractors in 9024 are different or look different than 9025
Tool Pants,
I used the tool to do all the rewiring for my DME 7.8 integration into my '99 and it worked pretty well. Not the best tool ever made, but certainly works well at a fraction of the cost of the factory tools.
Now on a related question, do you know if the AMP connectors for the DME are available as spare parts?
Todd
Today, I tried one of the 12 extractors on an oxygen sensor connector. It worked. Not as nice as the tool the dealership has, but you can't beat the price. And it is easier than shoving paper clips or brass tubes or jewelers screwdrivers into the connector when you want to remove a pin.
I have never played with the DME connectors, like you have. On other style Amp connectors I was able to decode them enough to buy them from BMW or Mercedes or VW. Are there any VW/Audi/Mercedes/BMW logos on the connectors?
At the end of one of my wiring diagrams is a list of all the connectors used in the car. There are numbers above each connector but they look nothing like a part number. The pictures are a sample.
Years ago Peter Smith showed me an electrical repair kit at the dealership. This kit also had a diagram of the connectors. There must be a way of buying just the connector, rather than buying a wiring harness just to get the connector. But I do not know how. I would have to ask Peter to see if he knows how.
